Waiting also.....lol![]()
Lets go ghostbusters lets go lets go !
Car cannot start and the system keep reset when I switch on the engine. ...
did damaged to starter, but already fixed n changed the part a month ago.... As you know the original car key there got sensor right, we only can switch n start the engine after the sensor detected(beeps sound trigger when detected the sensor). Now, the problem like when turn the key n the car try to start the engine, but somehow the system look like detected something, cut off the electric n reset the sensor detection again. It wont allow me.to.start engine...
now car at workshop, they said not electric supply to starter even switch the key on, found the battery going low n low... still checking what is the problem now.... if anyone face the issue before, please call me...
Send to Mit SC, did plan before if still cannot fix inthese 2 weeks will send there... thanks your advise....
Btw, anyone know where got expert workshop for This type of car on Butterworth/BM?
I agree with Bro gunnerzz. Since your starter was recently repaired/replaced, that would a fair place to start tracingLast time i exp similar problem on a waja.when i try to start, all light will either flicker or everything will shut off. If i kept trying, it will shut off when the key is at ON position.
What i do is remove the fuse one bh one and try starting the car.The car still refuse to start when all fuses have been remove leaving just the ecu and tcu fuse. hence it must be the starter as that is the only thing receiving current both at ON and Start. replace the starter and my problem is solved.
alright, let try my luck n ask formen check the starter, thanks you all comments to me....
Bro, how's your starter?alright, let try my luck n ask formen check the starter, thanks you all comments to me....
wireman checked n found te fuel pump n engine no electric supply, not sure ECU cut off or not? is there anyway to unlock?
maybe by default is KL, anyway I'm from Butterworth. Again, do you know where got formen know how to dismantle EMO sensor(that sensor on start switch area)?
bypas the emo, still cant start n formen found engine pressure not enough to start... is change engine is needed? cause formen ask to change engine.... got better advise?
the next High Performance Challenge (HPC) event at Sepang track on the 30th November 2008 are now open for registration.
