Yup Bilstein is good but its harsh, I test drove one fitted with Bilstein (forgot which series) it was harsh. Could on the wrong springs tho.
They have a few series. Sports one would be harsh. Maybe you do some research.
If I'm not mistaking it was on H&R springs, H&R is pretty known for stiff ride.
Bros, just sharing my Project 8 - Phase 1 completed. Complete handling department done - suspensions, steering rack and braking. I only knew that the car came with Eibach coils, so I replaced with original absorbers which was RM2600 for 4 sides instead of adjustables. Then new upper arms, some new bushes, rebuilt steering rack and the BBK.
Next, 3 more phases to go...
The original setup is already very well balanced as the 50:50 weight distribution handles just like a normal street car that is tuned very well. So using stock absorbers doesn’t mean it’s less better than aftermarkets. Moreover, it already has Eibach coils, which is meant to be used with stock ansorbers.
Ahhh I read that as coilovers, I'm guessing if you are not tracking it then those eibach is more than enough![]()
Nice BBK......
Original absorbers you get better ride......lol![]()
One more reason. Original absorbers will have longer intervals for replacement compared to adjustables need for rebuilds. Just want problem free for the next 5 years.
Yes better in terms of comfort and reliability. :)
But it's cheaper to rebuild coilovers than replacing absorbers, no? for each suspension, it'll cost you round 250 to rebuild while new OEM cost bout 600 each.
I've read forums where the KWs will run about 100k KM before needing to rebuild so that's about 4.5 years (according to my daily commute.)
With the current situation at my area, I really miss the OEM set up... Road is bumpy and terrible af due to construction of the new DUKE (I think.)
If it drives me crazy anytime soon, I'd switch back to OEM MSport.![]()
I feel you. My first set were Top perfect rears with original front rebuilds, meaning original absorbers cut open and rebuilt. They were good and able to handle my 200 horses, and yet still comfortable. Then years later, friend offer a set of D2 coil overs, and since my old set were due to rebuild just take over this D2 set. Woh! they are really stiff, might be good for track but for daily, really pain to the butt, but when fully loaded the ride is still good.....lol
a constant struggle to keep my sanity in check.Yeah why stock absorbers? Could get stock-spec absorbers, but with mono-tube, like Bilstein B8 for your Eibach lowered ride. B6 is suitable down to 30mm drop.
Those mono tube units are beefy.
I have bad experience with adjustables in my Airtrek perviously. Even though there were no leaks, I got unwanted knocking sounds from the top mount on bricked road surfaces. It's annoying when you hear tick tick. Using stock original absorbers can completely rule out this problem.
Additionally, I don't go track or racing anyway, and I use this for my family. So lowered with Eibach + stock absorbers is the best choice as advised by my mechanic.
Yes it’s annoying right? Glad you had yours fixed.
I like the new suspension system. It’s comfortable and yet handles brilliantly. So it’s what I really wanted.
Maybe should redo my old suspension and use back.......lol![]()
