Fishy Talk
BBpups,
did you adjust the brakes?
did you adjust the tension knob?
what was the weight of the lure you were casting?
what was the rod profile?
sifoo HO ... u kena spotted at papaya farm liauu .. hailatt liauu .. hahaha
i think i will just meditate around klang valley for the next few months la .. so most likely no bang bang for me oso in JAN .. must get all my things sorted out 1st ...
so most of the time i will be fishing in laguna laa ...
JUNH22A .. i just hentam another H22A until have to call tow truck la yesterday ... hehehehe ... but yes ... the info given by sifoo CHUN is correct .. u only pay for the fish IF u wanna TAPAU it .. but those fish taste like sheet one la .. believe me ... i know .. huahahahahaahaaa ...
will be going to laguna afterwards laa .. since didnt get enuff fishing done last week .. hehehe .. sifoo CHUN ... apamacam ?? coming ????
wa lau eh.. last minute all tangan gatal ar? sifu noel can fetch me or not wor... knn... no jarvis to use takde syok lar...
chun said:
jun: yes KElana Jaya!! and yes u need to pay for the fish if u wan to bring back.. but we dun see the point in bringing back Pacu's cos they aren't that tasty anywayz... kakakaka
btw hows the fight?
normally i play with siakap and jenahak only..
woah hentam h22a wor... apahal...
why larrr.. dont la like dat... haha
yaya , how's the fight ?? i long time never fish in laguna jor.
normally i play with papaya and PRC oni.... muahahahaha......
Sifu Ho , book for me la , if tat tiem tak boleh oni see how le..... march got mou ??
Sifu Q , pangkor gonna cost u less than RM 100 per pax neh, wat same old problem ???
Jun , dun play play hor , Sifu Q's car is a V-tec killer neh........ sure tapau vtec punya.......
sifu Q.... longtime never go papaya jor oso kena sported meh!!.....very tiu na sing lah....muahhahhhaah
sifu B... the airasia offer until this 18th niah.....so got a few days to booking mah.....
u want go on next March kah!! let me know which day u want to go lah....so that i can book this few day mah.... but hor...i only free on BIKINIng early month niah....
sifu b.... i plan go on saturday then come back on tuesday wor.... 4days 3nite...
reach there saturday morning, start with tiger 1st...... then plabuk on sunday noon or sunday nite lah..... come back on tuesday noon 4 or 5pm ..... can mou!! but hor i have to check with my tiger at home 1st lah.....coz scare she ka-ka cau-cau lah...muhahahahhahah
Jun, for a freswater fish, pacu is very fierce. For just rm8, you can try this species at Laguna.
Sifu Tate,
did you adjust the brakes? No......dono how to open
did you adjust the tension knob? Yes, depending on throwing big or small lure
what was the weight of the lure you were casting? Got heavy, got light. smallest one is the yozuri micro popper which totally screw up my casting :P
what was the rod profile? jarvis walker. trying to get a new rod
Sifu Ho, i saw you walking at Jalan Barat there. Opposite the Southern Bank.
I was in the mamak. called ur HP no pickup
FR Laguna
Everyone also no eat Fruit today. But as usual, tuesday not that much action. Past two visit were scary. My Line got pulled kau kau till cannot even retrieve line. Ended putus 2 times 4lbs and 1 time 6lbs. Today Same story.. Let it run like 5-10 secs.. then hook came off. Dont think can land it also leh coz using low poundage line.Other sifus punya leaders alot putus. Sifu Q now using wire leader.
Tomolo might be going too. Depends on SIfu Q's mood lah... kakakaka.
i will leave everything in car laa .. just in case got MOOD .. hehehehe .. havent had the sensation of line being pulled non stop for more than 2-3 sesconds long time liauu .. must cast far far like sifoo chai to kena those buggers one laa .. hahahahaa
wire leader oso they makan what .. hahahahaahhaaha
Wah.. as usual lah Sifu Q.. so early today~!
If going today, me gonna use ultraknot. SO many times d like that. wanna land it for once. But dunno can cast that far or not leh. Today most probably only u and me leh.Sifu chun last night said dowan right? Sifu Coltrain also doubt will come today ~!
yalorr .. most probably u and me only laa today since sifoo CHUN no longer hardcore .. hehehehe .. maybe he tengah kow lui leeh nowadays ?? huahahahahaahaa ..
ultraknot sure cannot cast that far one laa .. but u can always try laa .. hehehe
Sifu Tate,
Bro BBPups,
i think it's your brakes that is having problem which caused you unable to cast.
You do not adjust tension knob for big/small lures, you should be adjusting the brakes. Tension knob is just to ensure that the spool dont moves side ways much.
Yozuri micro popper is about 4~6 grams, which is within calcutta's ability, BUT it's your rod that is not matching. Try to get a UL BC rod. Search for ratings like 4grams~10grams lure weight(3/8~1/2ounce). That should do the job.
To adjust the brakes:
1: Remove the 2 protruding silver knob/screw
2: Take the handle + cover out. Worry not, nothing will drop out from there
3: Remove the spool
4: notice the other end of the spool(with shorter shaft) there are 6 centrifugal brakes.
5: turn on 2 of the brakes(just pull up a little bit, it will sound a click), which is opposite of each brakes. Meaning that to have a balanced rotor. (like this---> ON, OFF, OFF, ON, OFF, OFF)
6: assemble the set back.
Try cast a 1/4ounce lure(equivalent to 8 grams), that should fly but it may backslash a little. Dont cast too hard...
Cast 5 times with medium strength, just follow the swing. Back to front. a total of 180 degree movement. IF there are still abit of CBH, tighten the tension knob a little. Repeat the same steps :)
If alot of CBH, then you gotta remove the set and adjust on the brakes. You have turn 2 brakes ON, now you gotta turn 3 brakes ON. Set it like this---> ON,OFF,ON,OFF,ON,OFF...you will get a triangular shape.
Repeat steps.
Hope that helps.
pakai SPINNING REEL laaa !! hahahaahahaaaaaa .. no headaches !!!!
should be going to laguna again today laa .. since got monster pull sifoo chai line out so kow .. must kasi naik the bugger .. hehehehe
ME want revenge also lah.... 2 times go also cannot land those buggers~! today must land at least satu.
haloooo all sifus...
zth server problem meh? So hard to come in here wor.....finally can. Hahahaha.
Z
Replies
39
Views
5K
