[DIY] How to decrease engine bay temperature
3309
52
5
508
Nilai
I agree not perfect CAI but atleast there are still a lot of outside air coming thru the hose.
3309
52
5
508
Nilai
ha ha ha...yes agree with you...
Anyway whose car is that...I want to rolling on the floor right now...ha ha ha...
But I saw before someone install at his Odyssey a scoop with double hole....so daring...
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
hello guys need to know can this spray can also applied to engine block ?
where can i get ?
i want to spray my engine block to flat black any suggestion how to make it ?
I'm already take out all the internal part so need advise what spray can applied for block engine need flat black colour
:hmmmm:
yepp sure can use 1, manifold is hotter than block maaa
ken yeang
6,618
1,327
where can i get ?
:hmmmm:
make sure the engine block is free from oil stain, grease or dirt. If not the paint wont stick properly and your spray paint will be a wasted effort.
Try engine degreaser. They are tough on heavy oil, grease, etc.
30,002
Most engine degreaser are petroleum base therefore you may need to use soap to wash the degreaser off also and then let dry kao kao first
Saring
121
24
Tq will buy engine degreaser this weekend, and wait for block coming back from machine shop after that i will start to build it back :burnout::burnout:
30,002
Sent to machine shop, come back should be quite clean, right? If not in the car you can clean with whatever solvents, rather than spray degreaser. Just make sure no dirt and oil before spraying
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
or u can go to hardware shop & try to find water based degreaser, ace should have lot for oil & grease, its spray leave rinse method.
'(00): This is one loaded Altezza. Packed with a parts list even Taniguchi would be proud to drift with. Firstly, based on a 1JZ conversion, it's then treated to a 2JZ block, and then fully balanced with parts like HKS 264 cams, HKS pulleys, HKS extractors, HKS 3040 Turbo, HKS plumbing, HKS intercooler, HKS relocator oil filter, HKS oil cooler,
