Why you need this?
As we all know, overheating is a common problem among us Malaysians..
This DIY will help reduce the heating problem..
The only side effect after doing this is MORE POWER..
and the power increase differs between cars..
Gudluck
These are the things you need :
1. a few cloth.. an old t-shirt also can..
2. 4 screws.. same size & thread with ur hood screw.. but you need to get a longer one..
3. a few nuts.. this one u need to get 1 size bigger than ur screw.. it's hard to do if u use the same size..
4. an empty can of spray.. or whatever (i'll explain later)
5. a spanner.. of coz..
1st step..
Wrap the empty can of spray like this & place it in between your hood & car body.. make sure it fits tightly.. this will prevent your hood from crashing down on your car..
2nd step..
Open 1 screw & go to a hardware store & get a longer ones.. if your screw is already a long type, lucky you
Also get a few nuts that's 1 size bigger then the screw.. so, it will slide through the screws..
3rd step..
Put the nuts in between the hood holder.. MAKE SURE YOU DO THIS 1 SCREW AT A TIME.. as u can see there's 2 screw on the hood.. loosen 1 screw & work on the other one.. the number of nuts determines the height of your hood opening.. tighten all screws once u finish putting all the nuts..
4th step..
Repeat the steps above on the other side of the hood.. clear all your stuff from the engine bay, close it and u'll get this..
Happy DIY-ing
& Gudluck
* Proton Perdana users - need to cut off hinges from your hood 1st
Gudluck
1st step..
2nd step..
3rd step..
4th step..
Happy DIY-ing
& Gudluck
