guys, a noobie with a new DVC subwoofer.
according to my sub manual, its a 4 ohm dual voice coil and 300 W RMS. i got a 4 channel 4 ohm amp, 250 W RMS x 4, 500 W RMS x 2 channel. my amp cannot go to 2 ohm.
my question :
1. will it be sufficient to power the sub with only 250 W RMS (not bridge) ?
2. for a DVC, can I power each coil with different channel ? the first coil I will use the left channel and the 2nd coil the right channel.
3. my HU have a subwoofer RCA output. Is it OK if I split it into 2 then connect to the amp ? channel 1 and 2 will be bridge and same with 3 and 4. Then both bridge output I will connect to both DVC. I'm doing this to get the 500 W RMS output.
my question :
