To move forwards...active setup
sfoong1, how much u brought ur amp? is it match with the PHD component set? how do you compare ur amp with agako amp?
The amp is a used unit..Well, comparing to Agako...its definately no match...I find my current amp more power yet the bass is well controlled (Not comparing to the higher end amp).
Hmm..sound diff...at least my stage is up, up front bass..but no solid enough yet..
Hav u power ur PHD using ur HU b4? do you think power by HU will sound better than by agako amp?
sfoong1 said:
Yup..You are right.. Need to change all RCA....Before i go active, just wanna make sure all cables in place.
You still using stock cable?
Am using Stinger cables last time but not applicable since cable length is diff if i move my amp to the boot..
Used amp not a problem..
But it must better a lot than Agako la...
With the powerfull amp.. you can feel all you space inside you can can fill with vocal + music..
up front bass no solid can be helped by using you sub & move you bass to front... This one I done it when buy new sub ..
Write your reply...
