Need Advise for Tial Wastegate
evo5755
I am looking forward to get a Tial 38mm wastegate, but it came with "bar" standard. 0.5 bar and 1bar...now how do i determine which to get?
im using 0.5 bar one...first n second gear is nice...almost no spin...on bridgestone re001 and td05h 20g...but 3rd gear is lemau a bit...dunno why...maybe my car...and im selling my wastegate with banana for rm1.4k...plug n play for evo n vr4 with standard td turbine...
using stndard actuator how many 'bar' did you boost your car?it will roughly show the spring pressure that you needed....
wht spring rate to buy, its simple
buy wht minimum boost u would like to run
0.6bar spring can be turned to run at 1bar with boost controller
but there is no way u can make a 1bar spring to open up at 0.6bar
do consider a Turbosmart 38mm..smaller and lighter and flows better...single piece CNC valve for strength and precision.
http://www.autojunctions.com/index.php?option=com_fireboard&Itemid=59&func=view&id=321&catid=57
cheers~
Jin,
As always your explanation is good. This makes sense with irreversible boost changes..hehe.i will not be running as low as 0.5 bar, but will run from 0.8bar for normal driving or as high as 1.5bar of boost pressure for "sport" driving. So, can 0.5bar spring withstand 1.5bar of boost shall i tuned it with my Electronic boost Controller?
if you want to sell your wastegate cheap cheap can la...hahaha..anyway i think wastegate has nothing to do with your 1st 2nd 3rd gear response. There are so many more factors that contribute to this. Wastegate is a gate that dumps all the waste gas into atmosphere...
cheers~
Thanks SDF. Turbosmart will be in my consideration list too, but i wonder why the "pricing" is tad bit higher compare to Tial? Since this two is the most wanted wastegate in the market, perhaps price strategy should be nearer? Anyway just my cents ok..
perhaps in future you can bring in something called "Synapse" to Malaysia? :)
prices are retail.. i'm sure our Dealer will make you a deal when you visit them :idea:
as for Synapse..well..good stuffs..will the average consumer pay ? and with 2 outstanding brands dominating the market...well... you guys know the equation. :hmmmm:
better to use a boost controller to manage the boost level settings.
grab a 0.5 bar wastegate and it'll hold fine even if u run it to 1.5bar.
Actually Tial is nothing consider expensive comparing to thailand or chicken brand, of course tial is expensive... Compare with HKS, Tial has got no where to stand....
Tial is more of a affordable wastegate. that's why it's so popular....
Ok then. I will pay your dealer for a visit....:)
using the bov , wastegate havent used yet , time will come to fix it in
Are you recirculating the BOV?
Ok, so what is the real life difference between synapse and high grade Jap BOV( eg: Greddy type S,R & RS)?Zero surge? or very good sound? Or very reliable BOV?
waaa...this deserves a discount on your next purchase of turbosmart items. :biggrin:
