My head is gonna blow trying to solve this issue,
Wanna get some input from you guys
I run a T04E only, with a 38mm Tial wastegate
1st Issue
I cant half throthle and cruise on the highway , the turbo will keep on surging and the bov will open,close,open,close, switched to greddy type-r , still same issue
2nd Issue - boost issue
my tial 38mm is a 7psi model
with brand new hoses , it will boost up to 1.1bar+ , at times even 1.8-1.9bar
with profec b , its not consistant at all , 1.6bar -2bar
with turbosmart tee boost controller, turned it totally to negative , i get super high boost, wastegate doesnt open, last mind blowing, pissing in the pants boost was 2.8bar
i even opened up the tial to see the internals, all looks fine , no tears or worn outs , all clean inside , err wht should I do
bt one thng i really really realised , the turbosmart MBC gives me much much much quicker boost build up
errr , my intentions here is to get some ideas, 44mm wastegate needed ?
erm please, any unrelated :D i hit delete
1st Issue
