4g93 Mivec Turbo Waja project(Many pictures be warned)
Nightstalker1993
267
130
Subang Jaya
duuude.. how much was that spal?
You ask your friend la i got from him wan haha
Small Original intercooler hidden under the bumper towards the right side of the car
ohhh no wonder. Well mine is quite large Evo 4 intercooler up front so yeah... :laugh:
Anyway, more goodies just came in :burnout:
Bushings for my front lower arms are shot, so got some sweet aussie SuperPro PU bushing with caster correction and anti-lift properties :biggrin:
Got some springs from my friend to swap my overrated '1 bar' spring to
Also just sent my manifold to the guy to weld, close up of the crack :banghead:
Reactions: sanekit and Izso
Yup, all original including bumper that is plug and play.
Welding should just leave the weld as is. Looks like previous ones was shave clean and maybe was too thin.....
Nightstalker1993
267
130
Subang Jaya
Ok la, stock everything also good, less headache :banghead:
What you mean leave the weld as is?
Manifold removed
Swapping out the actuator springs, hopefully this will give me a base 0.7bar boost
Simple workings of the actuator.
Nightstalker1993
267
130
Subang Jaya
Speaking of fans, got ANOTHER SPAL puller fan this time to replace the aged Maradyne just for good measure. This one has a thicker and larger motor compared to the 13" pusher i bought and flows alot of air :biggrin:
Middle is the new SPAL puller, on the right is the SPAL pusher and on the left with the gold sticker is the old Maradyne.
Cool original SPAL bracket for my pusher. Need this if installing for pusher setup as conventional bracket will have it flush with the fan, leaving you no way to actually use bolts at the bracket.
And also bought a super fast reaction open-element NTC Intake Air Temperature sensor to replace the standard Mitsubishi closed-element style sensor.
Reactions: sanekit
Bro, gotta skip the Maradyne fan as earlier suggested. Funds too tight this round.
Actuator = wastegate?
Nightstalker1993
267
130
Subang Jaya
see how la, maybe just keep one side see who want haha.
And yes, i'm still using my stock turbo flapper 'wastegate', so the actuator controls that flapper
Nightstalker1993
267
130
Subang Jaya
Some update, manifold came back already and is already installed
When you buy a new manifold or when welding an old one, make sure you check for welding splatters which may come loose and wreak havoc on your turbine wheel. Saw this and grinded it off with a porting tool.
Also managed to replace my front LH side lower arm bush yesterday. Relatively easy to DIY, just 4 bolts literally. The front circular bush just hammer out and the rear square bush have to hold the bush with a bench vice and pry the arm out.
Old forward bush was really worn out and had freeplay in it, rubber also hardened and cracked already. These bush most probably was since the car came out from the factory in 2001.
With the new bush installed.
Installed the lower arm bush myself in around 1-2 hours time, will continue with the RH side later today. Do myself because mau save labour abit :laugh: . The forward bush was hard to get aligned because the rear bush hole is offset making the front bush offset slightly with the hole, have to use some brute force to get the bolt through.
Note to those interested in using PU bush, PU bushes NEEDS grease to work, please apply the grease that comes together with your bushing kit or search for Silicone Grease. If your PU bushing kit does not comes with or the seller claims it does not need grease, just walk away....
Reactions: sanekit
i would to ask the sifu around here... my stock gti sudden mati engine for few times... i go many workshop... but they cannot figure it out... battery ok... engine oil ok... a/f sensor still function... what could it be???
any idea please let me know...
cause i buy it for my little brother...
it is dangerous if it happen always...
