sorry la boss. :( :(Originally posted by BLaCkHoWLiNG@Sep 27 2004, 21:12
but some only 30 shots.
thanks for ur explaination, BLaCkHoWLiNG....seems that i'm really know nothing about cars.... :POriginally posted by BLaCkHoWLiNG@Sep 27 2004, 21:12
there are 2 types of NOS systems.... Dry System and Wet system..
Dry system consists of only a Nitrous Nozzle ... there's no fuel nozzles
to compensate for the fuel increase ... (i think some system uses a
device to counter the pressure of the fuel rail, thus raising the pressure
in it, causing slightly more fuel to be pumped into the combustion chamber)
A Wet System consists of a Nitrous nozzle, and a fuel nozzle... it jets
alongside the Nitrous Nozzle when activated, thus, giving d correct
precise amount of fuel needed to compensate for the changed air/fuel ratio.
It's safer this way...
As for the internal mods, well, most of the cars that underwent this
system was with standard internals. It depends on d model.. some
can take 50 shots... some 80... some 100.. but some only 30 shots..
mostly, 50 shots are very safe for most cars...
i think there must be some misunderstandings.Originally posted by WAJA2003@Sep 23 2004, 18:08
I my mimd i hv 1 idea,mayeb it also stupid idea
I wanan DIY NOS can arr???
Take a hose connect to PCV hose,or vaccum hose...
nather side hose pun in u car interior,that connect to some easy burn material...sheltox,DW4D or blah blah......
When wanna use NOS,just ask passanger press the sheltox aready connect to the hose...peshhhhh......
Can it hv any improve arr?? or it will kill engine???? i think i is stupid question lahhh......
Or can use BBQ gas also .....how say we install NOS connecter set,vut dont use the NOS ,we use GAS or nather material???
Can it done???
when NOS vaporizes, it cools the air . commonsense that when thing heats up, it expands. let's say 10cm square of oxygen has 100 oxygen atoms. if you heat it up, it might expanded to 12cm square but still has the same oxygen atoms.Originally posted by ksgoh@Sep 30 2004, 09:34
"when you reduce the intake air temperature, you increase the air's density, and this provides even more oxygen inside the cylinder."
how to do that? got device to control air temp??
what u mean by wet system, BLaCkHoWLiNG?? not all NOS is the same?
wet system makes girls wet when u hit the nos button![]()
jin only can take 1 shot per 10mins cozs he is old.
we are youngster still got the energy to kau tin 2 shots/5 mins.
huhu........................
