Dilemma - Engine Transplant Help
tatatititututoto
Malaysia
I'm in a serious dilemma now. I need to transplant my engine in 3weeks mine but i dunno what to choose. First thing's first. My budget is 15k, my car is a 1.3 satria. The part of JPJ clearance from 1.3 to 1.8 dun worry. I got ppl who can kautim for me. Now i need some help deciding what engine to choose.
Selection 1:
4G63t (VR4-RS Halfcut)
4G67 Engine kosong.
Transplant all the VR4-RS parts in to the 4G67 block and pay 1.8 roadtax.
Nissan Fairlady/Lexus/SR20 pistons.
PRO:
Engine modification parts easier to get.
Can take boost up to 1.5bar with out problems.
CONS:
Evo engine mounting f*cking hard to get.
Kenot use VR4 gearbox.
Engine is freaking old.
Petrol guzzler.
Selection 2:
4G93t (GSR Halfcut)
TwinPot EVO/VR4 Brakes.
VR4 Intercooler.
PRO:
Engine is newer, thus lesser headache.
More fuel saving.
Can kahwin with 'MIVEC' head.
CONS:
Engine modifications parts more difficult/expensive.
Engine is quite 'weak'.
Not that durable.
I have listed out my 2 selections, and I wish that all the sifu's out there can gimme a better understanding in which engine should i select. Both also are 1.8. Oh yeah, my ultimate aim is to boost up to 1.2bar. Will also install blowoff valve, wastegate, metal gasket, bigger fuel pump, injectors and piggyback.
Thanks alot.
hi there..im not sure watever ill tell u will help..but i suggest u go for 4g93t..im using vr-4 now..if i had a chance i wanna change it to 4g93t...vr4 is heavy,like u said its old..if u get the gsr...if ur willing to spend then rebuilt the engine...and vr4 got alot of prob wan la...i go to workshop until sien oledi la...seriously...think about it bro~ hope it helps...cheers!!
Urm... evo engine mounting where got hard to get?? Just pay a little bit more for stuff from Ralliart malaysia lah. Last I checked they have the Evo3 mountings on stock wat..
IMHO, Go for 93T, mod a bit and you might be pleasantly suprised!! Good luck
I think its pretty easy to choose.
If you have money to maintain choose 1, if not choose 2.
I will go with GSR because I move a lot, and I'd like an engine that I could trust.
Plunk it in, full service, overhaul, and love the ride.
4G63 from VR4 is very reliable... provided u overhaul it b4 installation!
if u like old skool got for 1 if not go for 2..
haha..
i would take 4g93t if i'm u.. :biggrin:
yo bro
i'm driving a gsr
in my opinion this engine is a very reliable engine
no problem at all since i convert till now
it is better to choose gsr than 4g67 with vr4 components
Option 1 is good only if you can get a standard 2 wheel drive RS gearbox; plunk in a EVO 2 or 3 to and make sweet music on the road. Since you can kow-tim JPJ, grind the engine number off and buy a 4G67 'birth-cert' with engine number for registeration. I know this has been done before.
If u can kautim JPJ n gila power 1 go for choice 1 la...
I believe it can be abused more than GSR.
But plz check for the wear n tear 1st b4 planting it into ur car.
Otherwise u'll start to get probs n get fed up wif the engine.
N wif ur budget u should afford to get a decent engine management. That'll help u save petrol n jaga ur engine.
go for 4g93t. like boosook said, 4g63 really heavy xD if i can turn back time i'll go with 4g93t
same headache
im having the same headache.. im having a 1990 proton saga 1.5 with all the standard equipments and engine.. im thinking of a transplant... wat do u all suggest ? but i need an engine thats reliable,fuel saving n i dun mind spending more cash on it while installing it but i dont want 2 have problem later on... it will be used mostly in town driving n far distance drving also.. is 4993t a good choice ? wat all should i do 2 it so that it meet my requirements? and how much will the budget be >
same here dude..ill change it to 4g93t if i could turn back time..damn.. :(..
aiyak , this thread reflects my post early 1 year ago :P
for my opinion , if u gonna mod it then its the 63t , if u gonna play standard then its the 93t
63t aftermarket parts are everywhere
93t parts abit harder to get
63t u can alwiz kahwim evo stuff
93t u can kahwim mivec head ler
63t u can boost 1.4bar without a headache
93t u can boost 1bar without a headache
63t u can alwiz opt to 20g turbine without worying bout lag
93t u take td05 also u lag kaw kaw
63t u already have a nice big intercooler in default
93t u take big intercooler u add your lag
63t u got stroker kits to play with
93t stroker errr dunno
63t u got 240-280hp
93t 180hp and to get 240 gotta spend lots of $
63t u got 2.0 default
93t to get 2.0 errr
63t no mivec head to play
93t can play high rev with mivec head bt still low compression
63t evo3 got high compression system
93t only one standard compression
63t upgrade availability is sooo much
93t alwiz got a headache with upgradability
63t in my car
63t very slow
63t no need lar
63t not nice lar
p/s : i tink u got fully confused hahahaha , bt i just need more spareparts , hehehehe
ceh... thanks alot jinkl for givving me more headache. from what i see both are very good engine. but seeing that the petrol price is rising, i will stick to GSR. muahahahahahaha!!!
Those with VR4 & EVO (especialy JINKL) god have mercy on your soul....
so in my case u all suggest that i should go for 4g93 or 4g93T?
if u can caw tim ngan jpj... why not u plunk evo engine?
newer than vr4...
as Jinkl said.... many true...
2.0 with stock standard got many hp than modd gsr xpended ++++ money.
evo fc bad?
to me not really bad. u need to know how to drive save fc.
