Racing Cam Profile, Anybody?
badbuddyz
D'sara
Anybody out there, Help!!!!!!
i just changed my vr4 head to a vr4 rs head. just thinking of a mini project, modification of cam. anybody with racing cam profile? that i can compare with stock vr4 with any performance racing cam?
i hv access with all the machining part. the problem is i cant found any cam profile in the net :( ....HELP!!!!!!!
vr4 rs(eci) cam is slightly higher than the vr4 cyclone cam.same with e1,2 cam.i think around 250.
actually i m thinking of regrind the standard vr4 cam to make the cam profile similar to racing cam. this project maybe a failure or success. we couldnt know. i need the cam profile to study the angles and regrind the standard cam. just an experiment....
HELP!!!!!!!!!!!!!
this may can help u............
Cams Tested:
Stock Mitsubishi
Web Cams - Street Grind
HKS 264 intake 264 Exhaust
HKS 264 intake 272 Exhaust
HKS 272 intake 272 Exhaust
Crower - Stage 3 Grind
Jun Stage 3 Grind
Peak Horsepower and Torque Results:
Stock Mitsubishi Camshafts:
Peak HP: 309.5
Peak TRQ: 295.3
Spool up on street: quick, full boost by 3.2K RPM in 3rd gear with good power when off boost and as it's coming onto boost.
Web Cams - Street Grind:
Peak HP: 314.3
Peak TRQ: 295.3
Spool up on street: slower than stock, full boost by 3.4K RPM in 3rd gear with less power off boost than stock cams.
Peak HP: 322.6
Peak TRQ: 314.0
Spool up on street: much slower than stock (the worst of all the cams) with full boost hitting by 3.6-3.7K RPM and a definite loss in power off boost compared to stock cams.
Jun Stage 3 Grind
Peak HP: 323.7
Peak TRQ: 323.2
Spool up on street: Car was not driven on the street.
HKS 264 Intake 264 Exhaust
Peak HP: 323.1
Peak TRQ: 333.0
Spool up on street: As good as stock (3.2K RPM), with off boost power the same if not better than stock.
HKS 264 Intake 272 Exhaust
Peak HP: 324.2
Peak TRQ: 333.1
Spool up on street: Slightly slower than stock (3.3K RPM in 3rd gear) and a very slight loss in power in off boost conditions.
HKS 272 Intake 272 Exhaust
Peak HP: 325.2
Peak TRQ: 323.4
Spool up on street: Slower than stock, full boost by 3.4K RPM in 3rd gear with a slight loss in power in off boost conditions.
i'm now using custom made stock evo cams with hks 272 duration profile...quite sluggy in low end but when boost comes in 3.8rpm can feel until end at redline..
errr i want to ask about regrind cam. as i know, they usually regrind the cam base circle to make the cam nose higher and has more duration.
but the base circle is the one that touch the rocker arm right ? how they install it ah ? if the base circle become smaller...still it touch the rocker arm or is it hanging ? or need any modification to the rocker arm ?
It will be hanging,,then we cover it back with washer to get back the lift:regular_smile:
