- Joined
- Nov 17, 2003
- Messages
- 2,336
- Points
- 3,138
I wanna get ITR TB but that thing cost quite a lot ler.....pokai ler
hattech-v said:yes putting the itr intake manifold only oso can feel the diff especially on high rpm...
last time i got 12 atw hp increment by changing the open pod air filter & itr intake manifold + itr injector.
shiroitenshi said:what's the difference with those tapered TBs then? (those with 68mm outer, tapering to 64mm at the butterfly valve)
What measurement do we take then? the outer? or the inner? From what my friends tell me, only the inner matters, but why the taper? venturi effect?
integramania said:J101 - Help me clear this one eg TB - 60mm ID, CTR TB - 60 or 62mm ID?
Spoon as u sed has the tappering on the intake....is this then better than taking a TB and borring the ID to the same from the front to the back since the venturri effect will be better? this way no nid to change the butterfly?
xxxx said:j101,
for the usage of ITB, u must have a standalone ECU rite? so, wat do u have in hand or wat do u plan to use?
