hattech-v said:before.
then sure stock b16b engine can be better if using re-map ecu...
hattech-v said:it can give better air flow. then sure hp increase. provided with tuning. torque not will not much increase since it reflect to displacement.
shiroitenshi said:ITB = less restriction I think...
How can it push more air in? NA is about sucking... turbo's are about stuffing..
NA sucks.. :P
zaki said:NA sux!! :P
lilvee is right. interesting fact on F1 cars. most stock production NA cars have engine efficiency less than 100%. if you want to have more than 100% VE, you can put supercharge/turbocharge or you buy a turbo car. turbo car can have more than 100% efficiency due to its capability to feed more air than an NA car does. F1 car can achieve around 130% VE. that's like boosting 0.3-0.5bar (??)
shiroitenshi said:but F1 achieves speeds that can create pressure at the intake point with thier special vents that direct air... (I thinklah.. I'm no F1 engineer!) I think it's called ram-air effect or something.
our cars ah.. at terminal velocity also not so much I think.. since the big huge ass bumper and radiator is blocking all the air.
lilvee said:In a simple engineering, torque will increase when power is increase. Torque is the function of power in:-
HP = Torque x RPM / 5252 :regular_smile:
achor said:ok... here's a question, stock b16a has single valve spring at the exhaust valve rite? or maybe it was single valve spring at the intake valve. mean while b16b has dual valve spring on both.
is this a fact or myth?
lilvee said:Ha ha.. Juz wondering, if last time when I'm studied got access to Google, i think i'll scored 4flat all the way... LOL
Google is our best fren now days... its free resources
hattech-v said:who create google aaa?
. So now I need to replace it. How much for the new antenna? Or any better aftermarket? Thanks.
