you really like to rub salt in my old wounds..![]()
You de-mod, he want to mod so can be win win mah.......lol
You de-mod, he want to mod so can be win win mah.......lol![]()
no rich one la..abit leftover after sell my old pc...hahaha..poor man mods..if rich i go for legacy and mod it...hehehe![]()
Gt g4 link evo pnp as now the price much more cheaper dy
PC of a pc which is known as computer or pc - personal car.....hehehe
thats a piggyback right?
personal computer..hahaha..its a stage by stage upgrade...not one shot..this coming weekend exhaust,then able to boost abit, ppl say angin lawas but under 1bar due to v6 fuel pump, then fuel pump/regulator..this time will go for 1bar..and see if there is any need handling/braking improvement..at this point, if got extra cash, ill go haltech + 650cc injector(expensive aftermarket injector) +ebc...else just emanage and be content with what i have..hahahaha
Engine damper, does it work? I mean can it reduce the chances of my mounting koyak?![]()
Nope, links g4 evo plug in is standalone ecu by links which direct plug in to your old ecu casing, plug all oem wiring back and mostly done except the hose for map sensor(maf to map conversion and also intake air temp input).. And there are much more function to play with as well.. If want more cheaper option, opt for power fc which ppl done for e123, saw one that day fast sold at 1.7k only, power fc job also pnp with much more simple procedure as compared to linls g4 evo plug in![]()
i put radiator for my processor.....
i worry body koyak, rubber mounting can change.
where can tambat, tambat lah....hehehe
try not always floored 1st and 2nd gear....i do that, once a while can lah.
gear 2 is the best..never use 1st gear, sayang gearbox.try not always floored 1st and 2nd gear....i do that, once a while can lah.
any particular reason?
my friend taught me how to drive a turbo recently, activate when at gear 3, then full boost, shift to 4 and repeat till 5.
1St and 2nd gear to powerful...hahaha
my wira chasis cannot tahan the pull, later engine go front only. Not the car...
Is light, but Tyre stick to road. Sure koyak....hahahah
your friend is right. Unless you want to rebuild gbox. If you are using normal gbox then its okla once in awhile , else like semi lock/full lock..theres high chances axle/shaft cabut from gbox if pull from gear 1.
gear two boost halfway, gear 3 4 5 boost till fly..![]()
Sportauto with the famous driver Horst has driven the new Skyline on N-ring.
*7:50 --- 157.787 km/h -- Nissan GT-R, 480 PS/1750 kg, Horst von Saurma, partially wet track (sport auto 12/07)*
Horst von...
