Rotating Turbo Compressor Housing ...
Wilson13B
Installing the new turbo and Intercooler piping but need to rotate the compressor housing prior to clearance issue,is it easy?
How to do it ?
FYI,the turbo have Internal Wastegate so the actuator still attached to the housing ...
Any info will be great,thanks =)
wat type of turbo u r askin bout bro? is it journal bearing?
wat engine u wanna fix in? pic pls? engine bay etc?
It's a IHI RHF 4 VF14 turbo,fitted on a L9 Turbo "EF-DET" ...
http://www.zerotohundred.com/newforums/attachment.php?attachmentid=290541&stc=1
My turbo is identical to this one...
One this i noticed is,the compressor housing of this turbo is different from normal turbo "TD05/Garett AR48/60/80" i play with before,all these turbo have the compressor housing casted with the bearing body .... but for this IHI RHF 4 VF14,the compressor housing is separated from the bearing body,so can i just remove all the allen/hex bolt then rotate the housing and fit it back,will the bolt be same pattern? Anyone came across this kind of turbo pls advice =)
Umm,i think this is normal Journal bearing turbine,cause stock car won't have ball bearing turbine fitted aren't they =? .... taken out from Subaru Legacy B4 =)
yup...no problem....
just make sure the oil/water inlet-outlet arranged accordingly...(inlet above, outlet below)
:adore:
and probably u need to fabricate custom wastegate actuator holder plate to suits new its new location...
u can always rotate the turbine to suit ur piping/setup, no problem
:adore:
But i just found new way to not disturb the water/oil inlet/outlet ... but i doesn't know if it work ...
Refer to my last post for the picture ~
The compressor housing is secured by 5 allen/hex bolt , 1 of them are longer so when it tighten,the wastegate actuator bracket just slip over and tighten with a 10mm nut ...
So can i just remove this all 5 Allen/Hex bolt,remove the compressor housing and turn it to the degree i want and fit it back,will the bolt align with the hole ?
Thanks for any info =)
yes u can...
