Guys,
Wanna shares my real-world experienced owned a Lancer CK with CJ4A 4G92 mivec engine+ manual transmission. Car stock standard inside-outside. BTW, I've owned it from 2001-2005, before settled down with DOHC Vtec H22A Euro R and CT9A until now.
IMHO, stock to stock Mivec CJ4A would able to out-run a B16A and mivec C4A anytime. In fact, the 8300rpm redline was easily achievable from 1st-4th.
real-time Speed vs gear positions for Mivec Cj4A :- (all RSM reading-max rev until cut-off)
1st gear : 83++rpm : Speed 62kmh
2nd gear : 83++ rpm : 103kmh
3rd gear : 83++ rpm : 148kmh (sometime 150kmh,depends on load)
4th gear : 83++ rpm : 198 kmh (sometime 200kmh, depend on load).
5th gear : 73++ rpm : 237kmh (topspeed. Tried many times. Car seems out-breath at that rpm).
Mivec strong gears from 2nd->5th.
As for the topic, since most of us comparing mivec CA with B16A and we all knew that mivec CA technology consider obselute nowadays, that the main reason why mivec CA always lost to B16A, on stock comparison.
HOWEVER, To my surprissed, my first impression on H22A DOHV Vtec euro R while taking possesion of the car in 2005 not so impresive, due to the gear ratio. FYI, both ratio vs speed for 2.2cc Euro R and 1.6cc mivec CJ4A are almost the same...in fact Mivec CJ4A better by 15%. it would be suprised if we put high-cam on Mivec CJ4A and run side-by side by euro R, I believe the CJ4A would easily wiped Euro R anytime!!.
Accord euro R gear ratio vs speed : (RSM readings, readline-stock car) :-
1st gear : 78++rpm : Speed 60kmh
2nd gear : 78++ rpm : 100kmh
3rd gear : 78++ rpm : 144kmh (sometime 150kmh,depends on load)
4th gear : 78++ rpm : 194 kmh (sometime 200kmh, depend on load).
5th gear : 73++ rpm : 241kmh (still have 10% to go , but I believe topspeed should be around 245kmh)
In reality, on stock-stock & same range cc/factory hp, I do beleive the Mivec is not as bad as we think.
