NeoCps 4-2-1 or 4-1? Power? FC?
4-2-1 peak hp is averaged to give broader powerband, 4-1 peak hp is higher by 5%-7% but powerband is narrowed down near peak hp only, u need to drive at that particular rpm to benefit from it, otherwise FC can be higher and not fun to drive when u like to vary ur rpm range.
best setup is 4-2-1 with 18"-24" downpipe length then terminate it with largest diameter bullet possible but back muffler keep it same diameter with piping size. this will give really fat midrange torque and driveable low end
Firstly, I am no sifu...
Afaik, for track high rev all the way, r3 cams are best for it, works am not too sure whetheris designed for road use where the torque is shifted lower rpms... U can never have both worlds with cps or any other similar type engines...
