RF comp is not well known. Lanzar amp are overrrated and what kicker are you using? Kicker ex, comp,CVR, L5, L7?Originally posted by bogieman@Jan 17 2005, 12:39
Hi Guys,
Need your opinion on my ice as I,m planning to upgrade.
current set up
Front Comp- RF-fanatik X 6ince
Amp- Lanzar Heritage 424 75x4RMS
Subs- Kicker 12ince
Thxs
if you take your electronics to the limit, i'll bet it wont last you for a year. its like driving a car constantly at the red line. precaution is better when playing with your setups.Originally posted by lks@Jan 20 2005, 15:48
have you taken your electronics to the limit? have you enhanced the listening environment, i.e. the car, the car cabin, electricity supply ...etc?
i think you should have your objectives determined first.
Originally posted by appleyard+Jan 17 2005, 20:34 -->
QUOTE (appleyard @ Jan 17 2005, 20:34 ) --QuoteBegin-bogieman
@Jan 17 2005, 12:39
Hi Guys,
current set up
Subs- Kicker 12ince
Thxs
RF comp is not well known. Lanzar amp are overrrated and what kicker are you using? Kicker ex, comp,CVR, L5, L7? why not start with a good HU and a good amp first. what is your budget for your upgrade? [/b][/quote] What u mean by overrated? is it the lanzar amp sound quality is not good compare to other branded amps? p/s : still learning.. thanks. |
overrated means that the amp claim to produce 10,000W power when it actually produce 100W. if you want to know how amps are overrated, try and check the fuse rating. if it has 2 fuse at 25 when it actually claim to produce 1000 W means that it is nonsense. in theory, higher fuse rating means that ti will produce higher output power.Originally posted by dracid@Jan 21 2005, 00:25
thanks.
