use S flow mufflet to improve the low end torque if u want. but u will lose the high end.
try what sifoo EG9 said...
update us on the results...
good luck and all the best...
Hi wfhan,
Thanks for ya advice. I'll check with him. He told me that he had done some setting on the distributor b4 I collected my car. Gotta check with him again.
Hello chek,
wah...when is yours going into ya ae111? Kanasai...you never tell us what's ya monster plan...
Blacktop and Silvertop all like that,all no power below 4k rpm.No need change throttle body,just service it.Do like EG9 said,check compression,ignition timing (with T-E1 jumped,10-12 degree),fuel pressure..reset ecu,see how it goes
Maybe u can try check your fuel pump? Maybe faulty? Just check..no harm...cheers..
any problem when using SVT wiring with BT engine?
