My own new ecu
synchron
Guys give me some oppinion on my own custom fully stand alone ecu.
The ecu will have built in ignitor and 2 bar map sensors. 8 AUX input and 8 AUX output. Best part is that it has Autotune function.
Only work in 4 cylinder engine currently. The ecu is design to work the all the Toyota 4 cylinder engines currently, especially the 20v and the s/c engine. The ecu is design to work with coil over plug and twin coil. 3 type of injector firring mode which is batch, bank and sequencial.
This link will provide the pic of the current software development. Software will be out next week for testing.
Ecu casing, connectors and its out looks is still under design.
http://f2.pg.briefcase.yahoo.com/bc/bcq771/lst?.dir=/ECU&.view=l
Thank you
Will be cheaper than other products in the market for its function. Only recommending it for street and sports users not the hardcore type.
Not really plug and play type, still need to mod the wirring. You will have less wirring on the 20v engine.
Will be running on TPS mode. As i said mapping is not really important since the ecu has auto tune function just like Motec and Autronics. The ecu will be able to adapt itself in about half an hour after running it. All you need to do is to fine tune the mapping after it is auto tune.
link don,t work
let us know the result and how much u want for it ?
good stuff....................
if its not too expensive.ill be ur no 1??
hehehhhahah
does it have an o2 sensor???and need to do whole wiring or just alittle bit?? 20%???
curious lar....wanna put for 20v svt. when all done, pls inform us, also the price too. if can afford to buy, will consider it.:) thanks
Sorry pal, Australia is Bill Sherwoods area.
Price will be cheaper than other standalone ecu's.
Price will be about 2.5k including installations and DLI coils.
As i always say quantity order will be much cheaper.
shit man, that's bloody good deal .............
got software to download and try or not? links to specification ???? the last one didn't work.
