Firstly, where is it leaking from? If its from the gasket seals around the water pump body, you can use rtv sealant to re-seal the water pump.
However, if it leaks from the pulley bearing, I'm afraid you will have to change the entire pump.
Hello.Last few days i go to ming heng looking for a recond japanese car. Then the salesmen recommend me this 2003 altezza AT for 12+k. So my question is there anyone had seen the car before? Is it worth buying this...
Hi, long time not active in this forum althlough i sometimes sneak in to view the contains here.... (due to some problem with my tme previously)...
I need help to find an actuator for replacement as mine is spoil (as...
