Firstly, where is it leaking from? If its from the gasket seals around the water pump body, you can use rtv sealant to re-seal the water pump.
However, if it leaks from the pulley bearing, I'm afraid you will have to change the entire pump.
Recently I decided to wash my car and the engine bay b4 Raya. As I wuz wrapping all the water sensitive component @ the engine bay b4 washing, I notice my cam sensor position is turned fully...
i have 'pasang' my turbo timer..and it's working.. once i 'tutup' my engine and the timer is on...then i try to lock my car but it's won't work..it's only work when the engine is shut down...someone told me that i...
