Later evos boost curve do have boost spike... it will spike to 1.4 bar FOR FEW SECONDS then drop to lower pressure (may be 1.2 bar..i'm not sure) under load. This curve is standard setting by the manufacturer. (look for top gear or fifth gear tv show..cant remember which one)
As with electronic boost controller, the 2 main functions are:
1-to set your boost
2-to set boost response (also called as gain setting- how fast maximum/full boost can be built up)- means you will be able to get maximum/full boost at earlier RPM.
The boost controller will limit the maximum boost pressure as set by you. if you set 1 bar, then the maximum pressure will be limited to only 1 bar with no boost spike,boost creeps, over boost..etc..whatever you call it..
Now we will talk about gain setting. If you set the gain setting too high,you will have the risk of boost spike. i.e: if your boost setting is 1 bar, then you set too much gain, there will be possibilty the boost will spike to above 1 bar before returning to 1 bar.
Conclusion:
1-Set the boost..
2- set the gain
3- fine tune >adjust the gain to minimalize or to eliminate the boost spike.
4- READ your boost controller manual on how to operate the controller
up to this point, i dont understand why you'll need a boost controller on the stock evo ix. when you adjust the boost controller, it will eliminate the factory boost setting which features the '1.4 bar boost spike'. And you will not want to set the boost higher than 1.4 bar or constant at 1.4 bar as the fuel system and engine management are still stock which is beyond the turbo and engine capability. ~~~~1.4 bar is considered high for a stock turbo and engine
And my previous experience of high speed cruising with evo was, I travelled quite often from KL to Terengganu few years ago. maybe once a week. cruising speed on the LPT Highway was 160-180km/h @ 4000,4500RPM. Water temp was perfect but still i had my cranckshaft bearings fucked.
It's beacause the engine oil must had been boiling hot as i dont have any oil temp gauge. The hot oil cannot provide enough protection for the bearings. I then had my engine overhauled. ( from positive sides: it's time for Upgrades
Lesson learnt for all the high speed cruisers, upgrade your oil cooler or install an oil temp gauge to monitor your oil temp. these few hundred bucks of investment will save you thousands of bucks and time. And water temp gauge too...Good Luck!!!!!
