Evo General : Evo I - X
@greenmivec,set it back to stock lar
Maybe because of difference in load between gear,therefore result in slight variation in boost but i am not firm on that
It should go up to around 1.4bar or so on mid range and taper off a bit by 7000rpm or so
Bro kariayam,
That is a very detail and clear explaination. Thaks bro. Actually the ebc is free gift that is why it is installed. That is the perfect answer why mine is 1.1 bar max only. Pity my evo cannot unleashed its full power
I understand the boost setting. I will set the value for 1.38 bar. But for the gain, what should i set? Dont really understand about it.
---------- Post added at 11:05 AM ---------- 6 hour anti-bump limit - Previous post was at 10:46 AM ----------
And that is why i m worry about cruising at high speed but i guess if we have enough gauge than we can take early precaution to slow down.
For me the best cruising speed for my evo is 140 - 160km/h.
By the way anybody have the m7 boost controller manual? I have lost mine
Bro kariayam,
My suggestion is just disable the boost controller or just turn it off if possible.
Why??? =
Spike means the boost will overshoot to 1.4 bar for a very short period of time( 2-3 secs) before coming back to normal boost (normal boost maybe 1.1-1.2 bar if i'm not mistaken) as from the factory setting.
You will not want to set the boost controller to 1.4 bar, as this only make your boost becomes constant at 1.4bar at all time and it's not healthy for the engine and the turbo itself + the fuel system is still stock + stock ECU.
REMEMBER: the factory setting only SPIKES to 1.4 bar, not sticking to 1.4 bar all the way
The easiest and best way for your solution is Just get your boost pattern re-set to factory setting to unleash the real potential of your e9 by disabling your boost controller.
Answering your question on gain setting, you have to do trial and error. you may start from the lowest gain, and try to increase it step by step.Find an open empty safe road, and try to push your car at high gear..(may be 3rd or 4th gear....and it's at your own risk too...)
You will see how fast the full boost is built up.. stop increasing the gain once you see the boost starts to overshoot above your earlier boost setting.
Huh..hope this clarifies.......:driver:...............and please dont blow the engine:biggrin:
Why??? =
the best and clear explanation:adore: can be a guideline to those want to install ebc later:biggrin: cheer :driver:
Yeah agreed, good explaination.
Bro kariayam,
Ok if i understood the boost controller function correctly, it will limit the boost level. Let say if i set it to 1.4bar. Since the standard boost for ix is 1.38bar and will spike to 1.4bar, that means it is a correct value to set am i right? It still allow the ix boost to be in its standard range, 1.38 spike to 1.4 and drop to lower bar 1.2 or 1.3, am i right?
Or are you trying to tell that if we set the boost controller to 1.4 than the boost will maintain at 1.4 and will not drop after that?
I have read a 52 pages thread of evo ix in zth, another point of ebc is to avoid a high spike since 2005 evo ix with magnesium turbo have the tendency to spike until 1.6 bar. Therefore if we have ebc it will limit it to the boost we set, let say 1.4 bar only and will not cross it.
But does it mean that the boost will go or maintain to 1.4bar instead of 1.38 spikes to 1.4 and drop?
Thanks a lot for making this thread a good technical thread to help new evo owner like me.
Bro GreenMivec,
Just in case you want to let go your M7 EBC, please let me know ye :wavey:
BTW, nice mean machine you have there :adore:
I dont really understand how to use the boost controller. If i set the boost, actually the mechanic set it, to 1.0 bar, does it mean all gear will be at 1.0 bar or will still varies according to gears?
There are 4 levels to set in my m7 boost controller. Level 1 1.0 level 2 1.1 level 3 1.2 and level 4 1.3.
If i use level 1, so it wont go until 1.3 right? But it happened to jump to 1.2 bar. Never experience 1.38 or 1.4 bar.
im running with m7 boost controller as well. actually that is not level 1,2,3 or 4. it was the preset setup that u can set. u can set level 1 to 1.4bar level 2 to 1bar also can. 4 setting for u to do fast switching without doing all the setting. im running in 2 setting in my ix now. level 1 is value 50 = 1.2bar and level 2 for value 60 = 1.3xbar. level 1 i use for town crushing. level 2 when i need more power..:listen:
---------- Post added at 07:08 PM ---------- 6 hour anti-bump limit - Previous post was at 04:42 PM ----------
Bro kariayam,
m7 ebc is the same as blitz boost controller. i got it downloaded in the previous tread in this forum. u can try to check it out. as for gain i only set to 10..... (slow slow boost up nvm la...)
but as i know if we turn off the EBC. the boost will only go less then 1 bar(shows on my pivot boost meter). i think by installing EBC something have to remove from our car...
Bro kariayam,
Bro, Ithink u better read my posts carefully..i think my words are clear and straight forward... please dont confuse with the 1.4 bar thing. I just type 1.4 instead of 1.38 to ease my typing since it's 0.02bar difference to be more exact..
if u set your ebc to 1.38bar, then the boost will maintain at 1.38bar...not more and not less.. You will not get any spike if your gain setting is low.
Bro aycy thanks i will search for it.
Kariayam,
Sorry for my ignorance. Try to learn from you and sifus here hihi
I hink i got your point. If we set it to 1.4bar, it will maintain 1.4bar instead of dropping abit right? Whereas a turbo should spike to 1.4 and drop.
Bro aycy
How does your ebc setting going? Does it maintain to the boost you set or it goest to the set boost and drop abit?
Kariayam,
this is what i understand what bro kariayam said, if u set 1.4bar,it will maintain 1.4 but u need to see ur gain setting, if low gain should be no boost spike but if u set ur gain higher then it still have boost spike..maybe the previous post u said "If i use level 1, so it wont go until 1.3 right? But it happened to jump to 1.2 bar. Never experience 1.38 or 1.4 bar" maybe ur gain a bit higher so that it still can spike till 1.2....correct me if im wrong..im also still learning so we can share our undrstanding
====>i take note from bro kariayam sentences "Now we will talk about gain setting. If you set the gain setting too high,you will have the risk of boost spike. i.e: if your boost setting is 1 bar, then you set too much gain, there will be possibilty the boost will spike to above 1 bar before returning to 1 bar"
Bro one shot actually all the setting were done by the mechaninc. Have not try playing around with it. The manual also in japan and not much can find in the net for m7 products.
We are lucky to have kariaayam to teach us
I need to learn the gain thing, to set boost level i think iunderstood already. Bro aycy i cant find the manual la, if possible can u attach here or email me ?
There are so manythings to do with our ix. I m going to sunway after his to look around. Looking for a turbo timer, may be apexi.
Here is list of basic mod:
1.)Turboback Exhaust(Downpipe,Test Pipe or High Flow Cat,Cat Back)
2.)Walbro 255LPH Fuel Pump
3.)Boost Controller
4.)ECU Flash(Go with Open Source ECU Flash)
5.)Boost Controller or Boost Solenoid(To use ECU controlled boost)
6.)Boost Gauge
7.)Wideband(If you want to monitor your A/F Ratio or self tuning)
As for #6 and #7,you can get Zeitronix wideband + display module to reduce number of gauge
Zeitronix : Wideband Engine Datalogging Systems and Accessories
8.)K&N Panel Filter(Stock airbox can support quite big HP)
After all of these is done,your EVO IX MR should be making 320-350whp or so on RON97 with 1.6-1.7bar of boost
Then you can do
1.)Lower Intercooler Piping(Reduce Turbo Lag,Increase few HP)
2.)Camshaft
may be you can google for "blitz dsbc manual english" because i rmember someone in this forum said the m7 is similar to blitz's.
Bro evofans thanks that is a good mod plan,
Bro kariayam, i found the manul. It is same with blitz type s ebc. Will look tnrough it and try to understand the function.
Bro greenmivec
take ur time to learn about the ebc..im also noob about this machine :banghead: dont forget to update here so we can learn n share together...:love:
Bro oneshot
I read here, a good guide
SwissCars / Blitz DSBC Installation
My gain set is 5, I think is sufficient, too much gain will cause boost spike. Will test the boost setting. My channel 1 the boost value is 53 = 1.1bar. Will set channel 2 to 1.38 bar i think the value is around 60, right bro oneshot?
---------- Post added at 05:00 PM ---------- 6 hour anti-bump limit - Previous post was at 12:32 PM ----------
Guys
I am lookibg for a turbo timer. Anybody have it please offer me a goid price ya. May be alexi pen timer?
Hi guys,
May I ask some common questions?
Trying to understand evos b4 buying one in future. Do these AYC pump or ACD pump break down quite often as i see a lot of discussion online bout evos complaining bout these parts besides common wear an tear?
Worst case scenarios will be of cause replacing the pumps but as far as in Malaysia concern is this a rare part? Or does Mitsubishi still provide brand new unit for replacement purposes?
Hi bro kher
Yeah the ACD pump is one of the major problem for an evo. If u use the diagnose machine is will show code 81 and 82, acd pump failure.
The cost is high but i believe it can be found here but half cut la. Or can order from Mitsubishi Malaysia.
The problem always occur due to improper bleeding process. Sometime the pump is okay but there is air in the line, by removing the air properly, the system will be fine. To know the acd system got problem is when all the 3 ACD lights turn on at the same time.
bro greenmivec,
how many KMs we should change the ACD & AYC fluids? I've changed mine once after I got the car.. workshop mechanic says dont need to change it so frequent.. unless the oil starts to get dirty.. is it true?:confused:
Hi bro kher
Oic... Thanks for the info greenmivec. How bout the AYC system? Does this system got some pump/parts that needs extra attention like the ACD system?
