IMO, replace better than weldLater got time will go and ask can it be weld back by add some metal plate.
Worst case might need to change the front frame I guess?
The crack is likely the source of your noiseJuz wanna ask is driveshaft is a common thing to rosak?
Driving my car few day and hear some weird noise while going through rough surface or those zebra yellow line.
driver side have sound kak kak kak kak kak while going through the yellow line.
Appears to be previously welded/repair. Better just replace outright. Not that expensiveActually, if can grind down to bare metal, see where the rust spread, need some rust prevention paint also, just spray inside, weldable paint too. If not, just cut and match, bend some good steel and weld.
Go potong shop to look for one
Bear in mind your engine sits on this. Next, try imagining it giving way when you are on the highwayBuying is quite cheap,weld balik is the expensive part. Hahahahahaha
I am unsure if that's the same piece. Need to ask the workshopWanna ask If I buy this and weld back better or buy a 2nd hand frame weld back better?
Wth buying so cheap, just buy. Labour expensive i guess? If theres a lot of things to remove
Where, how long does it takes, and most importantly, how much? :pfinally have time to send my Wira for a spray paint :-D
Normally to save cost, spray same color, so just spray outside good enough. But if change color best to spray inside also....How much does it cost? Do you juz spray outside only or inside out?
you better take out the player/hu and check to see if you have a short somewhere. EIther you have a grounding issue or your HU is going to rosak soonWira update
My car suddenly have an issue.
When I step on the pedal going to around 3k rpm my player will juz restart it self. Anybody know what is causing this?
Had check the fuse all ok no burn one.
While idling when rev to high rpm the player will also restart it self.
Similar threads | |
