Is Myvi 1.5 that powerful?
Few days ago, I saw a drag video between Vios manual and Wira 4G15 manual. Vios totally can't take lead even when the 1NZ-FE had 17hp more than 4G15.![]()
Maybe because Gear ratio?:hmmmm:
Seems like these high revving engines like 4A-GE, 4G92 MIVEC, B16A/B16B all suffer from weak low end. But how weak is weak? Are they even weaker than engines like 4G15, 4A-FE on low end?
Oh, so you are staying in KL. Probably that is why I did not notice your A31.
Is it the post about converted car chassis vs performance chassis?
If compare to satria 1.6 single cam for sure this car has better low end. I think toyota noticed that and they came out with 6spd combo with re-tuned ecu on the later levin ae111.
Google that up if you want to know more.
...but worth it. I was lucky to get this halfcut engine, which has only 67,000km on the odometer. Never had any major issue since that. Many wear and tear parts were replaced since owning this car, as to be expected of a 20 year-old vehicle. The suspension was upgraded to EK9 Type-R shocks and springs. Other handling upgrades such as rear anti-roll bar, stiff rings and some reinforcement bars were installed. The only go faster bits I put on the car are 4-2-1 exhaust header and a voltage stabilizer which I made myself. Other than that, the car is mostly in stock condition. I do most of the simple repair and replacement work myself on weekends, learning through internet forums and youtube. My wife often nags about me spending a lot of time on the car. I never let her drive this one though, hehe. I can see myself keeping this kereta buruk for years to come, banging through the gears on some winding roads. Nothing beats driving a proper manual car.
My 'garage' has 2 rides at the moment.
1. Proton Suprima S
http://www.zerotohundred.com/newforums/picture.php?albumid=3285&pictureid=11303
It's the primary car in my family. Bought it in late 2013. Use it for balik kampung and other long distance trips. Usually my wife drives this car to buy groceries etc. Handles very well and has very good torque. Safety is top notch 5-star ANCAP. The CVT gearbox is very relaxed but boring. Fuel consumption is good. Build quality is NOT so good. I've claimed many parts under warranty from Proton. The engine mountings were replaced twice and now the dash starts to vibrate again on cold start. The gearbox also jerks once in a while nowadays. Some foam has come out of the aircond vent. Oh, not to mention the infamous oil cooler hose (OCH) nightmare faced by CFE engine users.Google that up if you want to know more.
2. Civic EK
http://www.zerotohundred.com/newforums/picture.php?albumid=3285&pictureid=11302
This is the second car, manufactured in 1997 according to the registration card. Bought it from a bank auction in 2009. The original D16Y7 (M) engine died after it overheated. The overhaul job failed to save it. I replaced the powerplant with a B16A (M) and that broke my savings...but worth it. I was lucky to get this halfcut engine, which has only 67,000km on the odometer. Never had any major issue since that. Many wear and tear parts were replaced since owning this car, as to be expected of a 20 year-old vehicle. The suspension was upgraded to EK9 Type-R shocks and springs. Other handling upgrades such as rear anti-roll bar, stiff rings and some reinforcement bars were installed. The only go faster bits I put on the car are 4-2-1 exhaust header and a voltage stabilizer which I made myself. Other than that, the car is mostly in stock condition. I do most of the simple repair and replacement work myself on weekends, learning through internet forums and youtube. My wife often nags about me spending a lot of time on the car. I never let her drive this one though, hehe. I can see myself keeping this kereta buruk for years to come, banging through the gears on some winding roads. Nothing beats driving a proper manual car.
driver skills....![]()
EK has double wishbones at the front only. It uses multi-link at the rear. FC of Suprima is about 15-20% higher than EK.
turbo mahhh....street driving sure get bad fc.
Ur civic rays wheel..hmm nice
1. Proton Suprima S
Yup, most turbocharged engine nowadays use direct injection. CFE engine still uses conventional multi-point injection. Its compression ratio also is a bit low compared to other turbocharged engines nowadays at only 8.9:1. I guess this explains why it uses more fuel when compared to higher output NA engines like the B16A. If not for the CVT gearbox it would probably get heavier FC. However, it's not that bad lah, still considered acceptable. By the way, it weights about 1400kg without passanger, compared to about 1130kg for the EK.
If not mistaken, Like the Exora the turbo was tuned to increase torque not power......
138hp 205nm torque. Hp figures still feels very low for 1.6 turbo. New Civic 1.5 turbo gives out higher output.
As mentioned to increase torque, 205nm is higher then forester 2.0L NA......lol
Myvi is not 'powerful'. It's got a short gear ratio, body is light and it's got a lotta low end torque comparatively speaking.
Vios vs Wira - depends. MMC or VDO? And what's the tuning if MMC? The Wira VDO manual Aeroback or sedan? Kosong Wira or full spec Wira? The Kosong one is seriously light so if Wira kosong sedan manual - the Vios will have a tough time fighting in a drag.
Wira SE manual is heavy, so vs a manual Vios or even an auto, the Vios is gonna thrash the SE. But then again it depends on which SE? 1st batch where it had the extractor, exhaust and all the little gimmicks or the later batches where it just had heavy shitty rims and a loud muffler?
There's too many un-answered questions here.
Regarding my Sylphy - It's shit. End of story.
Even if the driving skill of Wira owner is better than Vios owner, Vios should be able to catch up if Vios's engine is more powerful.
Oh, all these while I thought Civic EF, EG, EK are using double wishbone on all four.
Although the Suprima is using a newer engine paired with an efficient gearbox which is CVT, it still gives poorer FC than a 20 year old design B16A performance engine.
This shows that even when B16A produces more horse power than Proton CFE engine, B16A still gives better FC.
Edit : Just noticed that you got over 1k posts. Congratulations.![]()
) It's that time of the...
