imitation rims - are they really not reliable at all?
shiroitenshi
3,676
170
i dunnow for others....
but for me... if running camber setup at -2 or more yet the tyre makan inside only means not fast enuf in corner... :p
last time been running daily -2 camber front and -1.5 rear....all wear out equals...but since now running normal tyre at front..so i just kept the camber more conservative -1.5 front..-1 rear...plus now change office route including 40km highways....save the tyre a bit...
btw i'll give u another trick that could save your tyre a bit and should give a better handling with slight comfort feeling compared to your current setup.....
soften both your front and rear spring...1k or 2k step down....then counter with the thickest ARB u can get..... try it :driver::biggrin:
yeah, but the speed you can carry into the turns with semis and hard springs is addicting haha.
well, perhaps I am still not pushing it hard enough on the corners too but since mostly highway driving, more straight than corners lol.
But yeah, I suppose 8kg is better, i should get around to changing it. My shocks did come with 2 sets of springs.
Just remembered something, i also recall that if you don't use a surge tank, you're not cornering fast enough? hahaha.
I honestly havent suffered fuel starve like that before, so i guess my cornering speed still needs more practice. ahaha
shiroitenshi
3,676
170
I've ran anywhere from -0.7 to -1.7 camber but toe is 0.
with stock bushing, your toe is only 0deg when not moving, when accel or decel, sure got toe change.
I remember someone recommend set slight toe-out on my car (sub 1 deg) and the steering was quite nice afterwards. But that was rubber bush era. now polys also run zero toe also.
But I think front toe out only works for cars with powered front wheels, like fwd or 4wd.
DeaconFrost
284
159
I'm still wondering why do car manufacturers use rubber.
Must be a secret to it. Or maybe the global natural rubber industry have some really sexy salesperson in their ranks.
on surge tank that depends on fuel load....if fulltank no matter how hard corner also didn't have fuel starve :biggrin:
regarding to rubber bushing...because rubber is a good vibration damper.....even heavy skyrise building and bridge also do have rubber damper (or called bearing pad) :adore:
shiroitenshi
3,676
170
like pomen said, "nvh" issue: noise, vibration and harshness, I use superpro also nvh higher than normal but quite good actually, lucky not as bad as my friend on sphericals,
pomen gtr
well if you run full throttle, that full tank won't be full for long ahaha
Sent from my GT-N8000 using Tapatalk 2
pomen gtr
:driver:
Cost! brother, the cheaper the better for them.....:mad:
---------- Post added at 08:05 PM ---------- 6 hour anti-bump limit - Previous post was at 08:03 PM ----------
If negative camber should be toe in, if FWD. FWD is pull therefore will toe out on acceleration....
But of course many ways of setting
Yeah, this is what I thought so too.
DeaconFrost
284
159
Well most probably for car manufacturers, profit from sale of car is a one-off, but profit from selling rubber bushes and other rubber parts is repetitive.
Looks like this thread is officially derailed hahaha. Sorry TS.
This is highly entertaining. Seeing some of the most senior members discuss cars is always entertaining. And senior in both member and age! :biggrin:
shiroitenshi
3,676
170
fwd is toe in on accel. rwd is toe out on acceleration. pretty sure it was that.
shiroitenshi
3,676
170
You are right brother. Got it mixed up. Mixed up with negative camber compensate with toe in....
yeah. increasing negative camber always creates toe out, so have to compensate with toe in. some people think they can simply lower their car without adjusting toe. if lower by a couple inches sure become negative camber and toe out.
PocketRocket
'(00) Mod'er
11,164
953
Up Yours
I wanna ask this, What about those Rota knock offs that nowadays you see on a lot of cars? For example mine as well, So far there isn't any dents, leaks, or imbalance
ixeo
4,788
3,080
KL, Malaysia
who made it?
any quality testing done?
no? then who can guarantee the manufacturing is up to par?
oh, it haven't fall apart? cool. maybe it won't fall apart, who knows?
using imitation rims (parts) is like having sex with no protection.
sure, wearing condom is not 100% safe. and you can argue without condom also you might not get STD or won't get some girl pregnant, sure, its valid.
So its your dick (in this case, your car), do what you like.
those saying even original rays engineering or SSR wheels also fall apart.. sure.. that's true.
you wear Okomoto 003 Made in Japan condom, you fuck at 10000rpm, the condom also tear lah.
shiroitenshi
3,676
170
then your tires aren't grippy enough to stress the wheels? /ahaha
Majority malaysians are using cheapie tires that in some countries are labelled budget tires, but due to the price tag, people think they are using premium tires. Then they say imitation rims are strong.
PocketRocket
'(00) Mod'er
11,164
953
Up Yours
I don't know who the manufacturer is but its a Taiwan wheel, As to what i've been told but keeping an open mind that it could be made elsewhere too. Doubt there are any testing being carried by JWL or those testing bodies. The way these wheels are so widely found these days of mass manufacturing leans to locally made for quick production and delivery. However I'm a careful driver, will avoid uneven roads and pot holes at all costs, even anticipate the routes I'm going to take to avoid killing the tire prematurely like bulging, uneven tire wear and road debris damage.
I think the tire I'm using is not too bad for a daily, Champiro HPY responds pretty well on dry and surprisingly well in wet conditions for RM300 a pop 17 inches is quite a buy considering its grip but I don't gun down public roads recklessly. (That's a whole diff topic). Never stinge on tires.
shiroitenshi
3,676
170
300 for 17".. er.... you mean there's even cheaper ones?
Can't say much on the rims, but the tyres I have them also. Same size as yours on my turbo VR. What I can say value for money. Yes, can say they are in budget tyre category but I jump from my GY Asy2 that are premium tyre category and these tyres are not very far off in handling and traction for both dry and wet against them....:driver:
Planning to do a transplant however, the car is mostly city driving and once a very rare blue moon the car is driven for long distance driving.
Want to change to auto trans also so need to find out which has a better fuel consumption?
1. 4g91
2. 4g92
3. 4g93
4. 4g93p
5. 4g93t
6. Mivec
7. Mivec MD
Hope to hear your comments ...
