experience on HWL adjustable suspension?
SE86
299
474
1,563
not onli absorbers play an important role..other settings like camber,toe in/out,tyres used also plays an important role..adjusting all this settings will effect in the responsiveness for your car. In my experience, i just did some tweaking to my camber and i can feel the difference. Cornering kaki must have slightly negative camber..but the tyres gonna have ware inside more than outside.
8k front and 6k rear..dengar pun dak takut duduk..
taza2504
hi everyone,This is my first post..i just want to know about saga blm spring rate from the manufacture??..i use know hwl..thanks :hmmmm::hmmmm:
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
i just want to know about ori vios 08 spring rate from the manufacturer?..n what best spring rate for dis r
both blm and vios stock spring is progressive.spring rate usually apply to linear spring that comes
with adj absorber.
infinity.melvin
SlowPoke
1,600
153
kuala lumpur
hey guys, currently im using myvi HWL adjustable 6k front, 4k rear for my viva..
im planning on changing to stiffer springs coz not stiff enough for me.. my rear feels kinda soft.
thinking of going up 1 notch, like 7k front, 5k rear?
i think 8k front and 6k rear is abit overkill..
btw, what is the cost to change front & rear springs?
Tan Kin Sung
From Facebook
Oct 26, 2010
24
www.facebook.com
My ride Kelisa using HWL MT-1 and my fren Wira also HWL MT-1 we are satify with the ride. comfort and also cornering. Only complain is the high speed compression a bit hard. How fast you guys want to take the corner. Street damper are not supposed to be too hard. Hard suspension will bounce your car out when you take a bumpy corner on the street. Is not track where road condition is flat and smooth. Is it really complicated when it comes to suspension tuning even Ferrari F1 team with a dozen of engineer is having a tough time tuning their suspension setup.
upontheriversky
275
82
if we go there and get a new spring with certain spring rate, will there be evaluation period where we can change to other spring rate in case it doesnt suit our preference?
my kelisa rear hwl is too stiff when going over bumps on the road at 100 kmh, i can feel the car jumped out from the bump already, feel unsafe coz cant predict the car movement at high speed. plus kelisa very light
hwl seems to gave me the track spec coz i didnt ask for specifics, bought it off the shelf and plug n play. front side can hear "psstt" when going thru bump, indicates abs motion but at the back stiff like sitting on wood, cant indicate the abs motion, probly moving so little due to hard spring
Supra_Fanatics
20,673
3,998
Going through bumps at 100km/h? :stoned:
No one would feel comfortable going through bumps at that speed...usually a person would slow down to like 10 or 20km/h to go through bumps...100km/h seems to be too fast..:listen:
zeckry zorano
15
5
1,503
penang
hai guys,
I need you guys opinion and suggestion.Im using satria gti and planning to install GAB MINES adjustable.My question is:
-Is it suitable for me to install that as i love to drive fast in cornering,plus what is the suitable heights spec for me to adjust for my hatchback car(gti)?:confused::confused:
-Besides GAB,TEIN and HWL,what other choices of adjustable that may suite to my GTI for a stiffer ride?:confused::confused:
D0m|n|k3i
27
6
1,503
Wira A/B....HWL 8kg f 10kg r + complete UR bars except front member brace, middle member brace & rear member brace. 15x7wheels 195/55/15 :)
Find it just nice. Not too twitchy yet even on high speed bad/uneven corners. But then again, it's up to individual preferences.
meltan7
619
32
Kelana Jaya
my car's running on HWL (8k front, 6k rear) with UR 4 point front strut bar and mivec rear anti-roll bar. so far, so good. gets a bit bumpy on uneven roads.
wow....rear using 10k spring???
mine previous using 8k front/4k rear on my daily satria.....perfect!....but my other half didn't like it...cos she said too bouncy (she chubby type body bouncing) :biggrin:
so have to resort on 6k front/4k rear......still did an awesome job on cornering and compromise with comfort....
HWL unit... :adore:
stix
Oct 6, 2010
41
508
myy
chubby? baru puas makan :eating:
anyways, thinking of getting fully adjustable unfortunately hwl does not offer that option. there are a lot of new players in the market such as ZerOne, ISC, BC Racing(taiwan).
all their adverts seems to be of good quality.adds to my confusion.
I have never driven one nor even viewed one before.
But Ninja Iga, assuming everything is constant and stock, with a bottle of Tufoil inside, I am sure you will have a slighly better chance to stand at the podium than others.
Others could be using stuff that actually retard their performance without them realising it.
