read n learn... :)
On 26/2 PG sprint Vaz-Maz(Rotary Savanna) clocked da fastest on da night and the only car that hit below 11sec (10.47sec) indeed Rotary King of Malaysia~Respect man...As my favourite Tung Chun also not bad clocked 11.62sec da fastest in 2wd turbocharged class.Originally posted by keong_MIRAGE@Dec 20 2004, 18:36
flamefox850,
if me,i'll go for NA VTEC rather then the vtec turbo... vtec turbo kena habis a lot baru power...u really need a expert to tune the vtec and turbo to work together,unless you buang terus the vtec system...see the vaz maz vtec turbo or not? very very fast last time,can clocked 12s something! and now the orange bullet from singapore,NA and clocked 11s something...damn ganas! ;)
Originally posted by 3R1C+Jul 22 2004, 06:20 -->
QUOTE (3R1C @ Jul 22 2004, 06:20 ) Originally posted by KillerB@Jul 21 2004, 08:36 AM
--QuoteBegin-eclips3
@Jul 21 2004, 10:00 PM
turbos were banned coz it killed a.senna rite?
no, it's the active suspensions that killed a.senna.
true :( the suspension went thru his helmet and thru his brain :ph34r: RIP the legend :huh: [/b][/quote] the steering link was beeing cut n welded back bcoz senna was complaining he can't see the road to his engineers...but welding was poor n the steering linkage broke n when crashing into the barriers the other half of the broken steering linkage has poked senna's helmet...and boom...into the sky another legend after the great Gilles Villeneuve.... :( |
u should understand turbo is not a super power..Originally posted by AccordRacing@Feb 28 2005, 20:15
turbo power come out b4 3000rpm after that rev high 9000rpm to v-tec power,turbo for pick up n v-tec for top speed,both combine sure best
Originally posted by rotorian^29+Feb 28 2005, 09:05 -->
QUOTE (rotorian^29 @ Feb 28 2005, 09:05 ) --QuoteBegin-keong_MIRAGE
@Dec 20 2004, 18:36
flamefox850,
On 26/2 PG sprint Vaz-Maz(Rotary Savanna) clocked da fastest on da night and the only car that hit below 11sec (10.47sec) indeed Rotary King of Malaysia~Respect man...As my favourite Tung Chun also not bad clocked 11.62sec da fastest in 2wd turbocharged class. Happy Motorsports To All~ :D [/b][/quote] pasir gudang drag race....the timing is based on 0-300m arrr??? tats wat i heard la. so is it 0-300m??? |
ace79 said:usually engine oil level, whether your oil pan is leaking oil or not ( especially over the oil return line to turbo vice versa ), check boost pressure, exhaust temperature, check coolant levels often and that coolant is not leaking anywhere. maybe there's more or less to look out for.
