Sorry if i offend anyone...
I think the gasket is not too good, got to do a top overhaul...
There again i might be wrong...
Please check first....:stoned:
Yah, I remember my mechanic did mention something about this also, but cannot remember the exact explanation. Something to do with compression leakage....
---------- Post added at 07:39 AM ---------- 6 hour anti-bump limit - Previous post was at 07:37 AM ----------
dude... put back your thermostat... the water is passing thru d radiator at a rate faster than it can cool down.. if u r worried it may not cool enuff as u wack it at high speed, u may drill 2-3 small holes at d side of yr thermostat but NEVER-EVER-FUCKING-REMOVE it... then make sure u got good solid wiring to your electrical fan and u r using good relays...
Many years ago I tried that, and most of the time it is running below operating temperature and was not good for the engine either or even worse....
