Radiator spare tank overflow
Sounds like head gasket leaking,allowing combustion pressure into the water line,check your spark plug for whitish residue.the head gasket might be leaking in either of the cylinder.your overflow tank is filling up maybe due to excessive pressure from exhaust pressure.
if head gasket leaking, there should be oil residue in d radiator water right?
i'd say, u should cold start ur engine without ur radiator cap..
let all the bubbles out of ur engine & refill water till full..
do that for about 20minutes.. that should solve ur problem..
if problem persist, please see your doctor :wink:
I thought you were the doctor......:rofl::rofl:
Update:
1. Did radiator pressure test. No leakage found.
2. There is no sign of water in engine oil.
3. Car sent to workshop. The truth will be reveal soon. :afraid:
I think it's that 1.1bar radiator cap problem
My radiator cap is new, 1.1 bar. Bought at spare part shop. Itu ok ke? =X
Thanks for the info!! :adore:
If symptoms still there, try another radiator cap. Never know, because even new cap can be faulty......
I got the engine head skimmed, changed gasket.
Problem Solved......
Thanks guys!!!
For helping me out!! Really Appreciate!!:adore::adore::adore::adore:
Moral of the story : There is no 100% in everything :proud:
Thanks guys!!!
So your trusted friend, can still be trusted?......:biggrin:
