mods on Accord CF4
abit more modification then i'm done, now to spray the whole thing to euro r's red, heheh
Mana tak nyer clutch terbakar. Aku rasa sebab main half clutch jer. Malam tu keta ko & Anis memang power!. Phase ECU ko baru dapat ker? Is it not duplicating works with VAFC & RSM for VTECH point & cut off?
Kete aku mana ada power, powder ade la. kekekeke. Anyway, pasal CL1 ECU tuh, susah nak duplicate sebab OBD2. Direct connect. Eprom tak ada. AF mapping Boleh buat la tapi kena pandai2 buat. Matspeed pun geleng kepala jer. Kena buat reversa Z-->A. Banyak kerja tuh.
ECU Phase tuh member aku punya, pinjam dari budak S'pore. Nak jual dalam SGD2.5k-SGD3k. Tak berbaloi la. Tapi Vtec bukak 6500rpm kot. Tak de la rasa sangat. Aku ingat std lagi baik. Phase pun remmaping dari ECU asal CL1. ECU CL1 Matsushita Jepun buat.
hello guys,
i have a H22 header, a brand new flywheel + brand new stage 1 racing clutch for sale. the flywheel and the clutch will suit any H22, H23 or F22 models. if u interested to c the items pls gimme a ring or sms me at 019-3798863.
the H22 header is used but in perfect conditions and it was taken off from a euro r.
thanks.
jb
kete aku la buat ambulan bai... sweeper... dah le kaler putih tinggal nak beli sticker bulan sabit je.
minggu ni mbalik kg la... xleh join tt gak
amdfaisal said:
apasal separa...?? meh aku bawak g fix it right bayar die 2600 pastu kasi die cat kete kau....
nak kaler ape bai???
young banana leaf green?
sweet yam ice cream purple?
rainbow??
haiiiiii.............bule antar tapi hang bayar okie ka....selamat petang abang abang CF4
JuizeeeBrain said:
hello guys,
thanks.
jb
Mind to share what engine / car u running now?. Cause if H22A CD6 or BB* Prelude, confirmed the header can't fit into CL1. Stuck at oil sump & front lower block. Nanti oil over-heated & will damaged conrod bearings.
Techinically for normal H22A and CL1 H22A are same...but not that same (sama tapi tak serupa). FOr instant, plugs also different. Pelik isn't?. Anyway, about the clutch plate not so sure though cause previously i try to fit the local Honda H22A clutch plate into mine. Can fit..no problem but finally gears can't shift. Sangkut2. Donno it's because of fake local Honda parts or it's not ngam. TO solve it, i just bought the clutch kits for CL1, base d on the product code on the CL1 manual book. Guess what, no problem until now. Sames goes to my altenator bearing. Pening2
In short, in my opinion & experience, this CL1 & CD6 H22A parts are like 'serupa tapi tak sama'. Unless other people have a different experience to share.
Ambulan dengan black DC5 rims. hmmm..boleh curik rims tuh. kekeke
avant nak test power ni... EK 99 sepek lawan euro R... dasat...
avant, kete kau skrg ni kau dah buat ape?? bagi la list modifikasi kau. mesti ganaz punya... mana power antara kete kau, lori ngan hattech??
psl fix it right tu suruh mynnDAWG belanja la bai... heheh... die banyak rekemen orang mesti ada saham dlm kedai tu hahaha
Kalo nak test power Ek99 sepet dgn Euro R, aku rasa EK sepet kena bagi ER handicap la..2 kete la!!. kekekeke
kedai tu nama die grandpire... fiber je tp quality la... keras... dah byk kali dah sagat lip depan aku tu tp tak pecah... jester la yg introduce. mcm2 design ada... klu nak buat grill pun bole gak.
full address wa tatau la pulak tp die kat sunway kat area kedai potong tu kat belakang2 sket... klu kau nak aku bole bawak kau ke situ tengok. ari jemaat ptg ke... ngular la sket heheh
amdfaisal.....any ombak ombak look on the lip when taking side view....i saw many fibreglass bodykits do have ombak la...no smooth....
no ombak2 la... maybe a little kot but not noticeable la... the most undesired thing is the uneven gap between lip and bumper. easily repairable when you send your car for repainting but i did not ask the paint shop to do it for me because i wanted to put those rubber linings to fill the gap between the lip and bumper.
I'm still new to forum, may i know what is T T ? still trying very hard to learn all the jargons you guys using here, hehe :)
