i tot its called FICDAlex - try to adjust your VSV for A/C Idle-up using an allen key...look like in the picture given below...normally located near the firewall next to the wiper motor...
Already solved this problem after running on MAP...try to check ur steering rack vacuum hose, if tertanggal or poor hose condition will cause the problem u mentioned..
if everything tried, it's time to change blacktop wiring running MAP...hehehehe!!!
Nop, use back SVT original wiring. Only bought BT ecu. MAP and Air Intake Temp sensor use from 4AFE. Re-pin ecu socket to match it with BT ecu.kimi; u from svt to bt full wiring? how much tis cost??
feipepe, are you using auto wiring? If you do sure i can make it for you, but if you is using manual wiring, there is a bit problem coz ecu socket didn't matchkimi,
can u help me to do that?....i can pay back the money to u...
They are diff......... if i not mistake, svt manual socket are sames with svt auto...
