Idling and Rev Issues
tetekpower
Sifus,
Got a series of issues re. my car's idling and response. The zero-load-idling (no lights no air con) has always been around 900 rpm but drops to 500rpm when headlights are on, which required a little bit more effort to occasionally blip the throttle. FICD fitted steadies the idling when air cond is running.
Recently, the idling worsened; even when lights and air cond are off, it drops to 500rpm. And the ride seems more jerky, rev drops quicker when throttle is released and engine stalled twice after pushing hard (most recently on the way to LCCT at 180kmh average, was late to pick the missus up as I lost track of time during happy hour..haha - the car just mati when i slowed down through a corner - check engine light came on)
So, the nxt day took it to the mech and managed to get somethings fixed e.g. idling steadies at 1000rpm when engine is nice and warm. The following morning, noticed the annoying 'tit-tit-tit' sound during engine check, was gone, and so was the cold start - normally the revs were at 1500rpm during cold start. What happened? Aiyoh! But all these new discoveries aside, the rev steadies at 900rpm to 1000rpm with warm engine, air cond and lights on. However, the ride is still jerky and revs drops quickly when throttle is released. Feel as though something is not right. Here are some questions on my mind:
1. Should send my car in for re-tuning? Has my emanage gone kookoo that caused my car to mati? Lucky I didnt mati in the corner...haha...choi...choi...
2. Has there been a change in my timing that is causing the jerkiness?
3. Is there a fault with the O2 sensor?
Anyone out there able to share some thoughts? So sad...
Much appreciated! Thanks!
:hmmmm:
ehdrian...throttle body cleaned already...:driver:
could it be an injector-related issue?
sifus out there...wwhheerree aaarrree uuu?? haha...:adore:
ok found the problem..fuel pump was slacking and injectors dirty...chucked in a walbro255 and gave the injectors some cleaning...tadaaa...performance restored...thanks for ur time guys!
I also got this problem when i slow down at corners, engine will mati. But my fuel pump is new. Injectors cleaned. Using emange blue. Cold start at 1200rpm. Normal idle 900rpm. But when slow down idle will drop below the 500rpm line just a second it come back to 900rpm.:bawling:
Although the drive is more responsive, I still observe rapid rev drops after releasing throttle. But it will stabilise after a second. I wonder if it is a problem with
1. emanage?
2. spark plugs or cables
3. distributor
4. compression (as suggested by proPIPING)
I'm running B16a, feel's chip, emanage blue...recent additions include walbro255, cleaned injectors and throttle body.
1. emanage?
3. distributor
maybe the fuel ratio is too rich...
fuel ratio? serious ah? if only got wideband...haha...ok i'll try to get my mech to check out the AFR...thanks propiping...
Write your reply...
