rollakid said:
my car dun have speed sensor(the one behind dash) and o2 sensor, other than that wiring should be good, the mechanic is reputable one. fuel return line is not connected tho.
ecu memory i'm not sure, but its used by someone i know before but he's not complaining anything. other than that, just my shim is making damn loud noice, kinda cool when i rev it hard, but sound exactly like diesel when idle.
my timing might lari abit, i'm looking for a timing light gun now, but not yet obtain one. I've set the timing myself to the idle rpm recomended by the service manual, not by degree, cuz no gun to test. when the engine is hot, things is normal, beside jerking, but when its cold, it idles very high.
today its raining so its cold, i start the engine and it idels at 1600rpm instead of 1500. drops to 1400 after 10 second. drive abit then drop to 1200. and as usual, if i race it hard, it idles at 900.
Ok,I have run my svt without speed sensor,knock sensor,O2 sensor,ELS1 signal,ELS2 signal,and a/c amp signal before,now all is connected except for a/c signal since i'm using ae86 compressor,so i have to check the wiring first can suit or not.
Speed sensor = it have no effect on idle in my car,but i notice when i disconnect this wire,idle goes up a bit,maybe the ecu do this for fail safe measure since it does not know the car running or stand still,so it does not want the engine to stall.The rev cut will be at around 7600 only.No check engine light come out for 6 month,after that,check engine light come out when i drive above 140 in 5thgear,gone when switch off and on again.
O2 sensor = No effect on idle also,only when i connect it,engine feels a bit smoother,FC just a bit better(5km more journey)
Knock sensor = VERY IMPORTANT,just go get it if u dont have one,the ecu retard the timing when theres no knock sensor,engine feels sluggish
ELS1 = Brake pedal switch,voltage signal input to ecu
ELS2 = A/c blower voltage signal input to ecu
I think the loud diesel noise comes from the vvt pulley,mine also have.
The ecu memory is important also,it stores all your driving habit there to adjusts the engine time to time.If you dont have this connected,when u drive the car,the ecu learns,and it stores tha data in the memory,but lost when u switch off.If u connect,the memory will be alive and used when u drive again.So the ecu dont have to learn again next time.Ecu memory pin is BaTT,check this,make sure it is connected directly to the battery with 10A fuse
Set timing with the T-E1 shorted,at 10-12 degrees
This is what i know..i'm not mechanic
