brother Syah.. you mean even E8 and P1000 in the same car ... the P1000 can tune out more HP ??? If really ... it quite amazing .... need to have a try ....
Not try,should change it ha3...skayline ble beli bro..how come cannot change the computer..he3
if change the ECU can gain horsepower ... I dun mind to change ... if only new software and some new function without gain horsepower ... then no point to change the ECU unless I really need the new function .... hehehe ....
Hi,
I would like the PWM control to control my VVT and set it ON at 2.5k rpm and off at 5k rpm. Can you let me know can I do that ignoring the load function?
I only want it to open at 2.5k and off at 5k.
thanks..
I need some tips,
My mapping for both fuel/ignition is frm 0-8000rpm where the redline is. While practicing 'driving' my car, i always manage to kiss the limiter thus making my car go brap..brap because of the ignition cut.
I was thinking of copying the map value across the 8000rpm range and paste it in the 8500 & 9000 rpm table cell that i would like to add. This way it would provide with a wider margin to shift at the 8000 rpm.
I think the AFR would be more or less to the 8krpm map. [dont hav wideband..:(]. Plus i wont be actually shifting at 9000, just so can give me some space if i cant shift perfectly around that rpm (setup at 7800rpm now)
any experienced/hands-on sifu would be greatly appreciated.. :]
