d'carbo expensive laa........
use STP carb cleaner..... less than RM20......
Bump: d'carbo expensive laa........
use STP carb cleaner..... less than RM20......![]()
Check up this link..
http://sg.redad.com/viewad.asp?id=50323730277169798
Voltage stabiliser. save a bit around 1-2% on my car. in addition u get cooler air con and smoother ride.
i got also one product can save up to 35% fuel.
it is called K2N Magic Stone.
If you improve everything, lighten everything, it is time to change the way we hit the pedal... If you kasi hentam all gears at rpm 5++, sure koyak man... Better keep it under rpm 3...
yeap.
my turbocharger kit is very easy. DIY.
install vacuum cleaner to suck more air into ur intake manifold. less than rm1k setup.
too boring to talk about fuel saver afterall most of them doesnot work.
buy idsl engine and dump into ur car guarantee save fuel one.
DIY hybrid car also save fuel. take washing machine motor and mount to rear wheel.
With std and stock injection engine, O2 sensor, throttle position, air flow or map sensor + ecu will control on ur fuel consumption.
Just makesure all of them are in good working condition.
Btw, gear ratio will affected on fuel consumption as well.
Slightly advance on ignition timming and remapping ecu may help u to improve as well.
However, from my past expriance, voltage stabilize really can make a job nice.
can feel engine go smoother after installed, especially on 6A10 engine.
Besides, go to branded part to gain better value.![]()
anything that can do 'Electrolysis of water' is good..
i use a device that called 'E-gas Hydrogen fuel saver'.. it's save fuel & give a lil more power..
not much.. but ok la
Definitely there is a saving to my pocket because of extra power obtained from the addition of Hydrogen & oxygen sucked into the engine. It does take some electricity just like power amplifyer,(about 10amp), but what the alternator is used for. Another draw back is that the stainless steel wire acting as anode deteriotes through time like electroplating. This is a D.I.Y. gadget. Dont buy it if you are lazy to open up the bonnet every week to change water, (because the system depends on water, and the more often you change, the better is the performance). Because I like to delve in mechanics and repair, that is the reason why I still have them in my 3 cars for 3 years alridy. I sold a few, but these people gave up after a while. Too much of a nuisance. Better buy those gadget like voltage stabilser which is plug and play, with one fix to the battery and another to the cigarette lighter. Mega Raisin brand made in China RM60 each will do the job. Yusofngah (not my real name)
Ok lads, since petrol prices are at pocket bursting prices, lets help each other by listing down the FUEL SAVING DEVICES available in the market today.
What works:![]()
1. Name / Brand / Price / Proof
2.
3.
What doesn't:![]()
1. Magnet on fuel lines / Many brands / Not cheap / Proven NOT effective by Mythbusters.
2. Air Injector a.k.a Compressor / Many Brands / RM200 to RM500 / Self-used, and many other friends as well, all not working.
3.
P/S : Hopefully, after some useful input is gathered, i'll be able to publish an article for the ZTH main page.
