Save Fuels Save $$$
FuelSaver
singapore
Fuel Reformulator that Saves Fuel Up to 20% ONLY FOR PETROL
Tested and proven by various Government and Industrial experts in their respective
fields and backed by 1 million dollar ‘American International Group Inc’, Atoms PowerZ
multifunctional Fuel Reformulator is making a difference in the world by making our
vehicles more fuel and performance efficient.
Atoms PowerZ is a unique multifunctional breakthrough Fuel Reformulator that effectively
causes fuel to burn more efficiently and optimises combustion. This results in a cleaner,
more lubricated engine that operates at cooler temperatures and runs smoother with unnecessary
vibrations, protecting the engine from expensive repairs and requiring less maintenance while
extending its life. Most importantly, it is the easiest, fastest, safest and most cost effective way of reducing air pollution!
SECRET FORMULA
Comprising of a unique formula of high-quality natural esters, Atoms PowerZ is non-toxic,
non-hazardous and free of carcinogens. The unique natural esters in Atoms PowerZ is made up of 100% plant quintessence.
It is not derived from petroleum and is fully-biodegradable. Laboratory tests confirm that Atoms PowerZ is clean and safe upon ignition,
reducing emissions without adding any of its own components to the exhaust and is 99.999% ash-less upon combustion.
Only 1ml of Atoms PowerZ is required for every 1 litre of petrol.
BENEFITS
When Atoms PowerZ reformulates fuel, internal components of the engine benefit from the lubricating and cleansing properties.
This includes the fuel lines, filters, carburettors, spark plugs, injectors and all engine seals, keeping them tighter and longer lasting.
The cleansing properties also prevent new carbon deposits and remove old deposits, which robs the engine of power and performance.
As a result, horsepower and torque returns closer to the manufacturer’s specifications while experiencing better fuel economy. Less carbon also results in cleaner
and longer lasting spark plugs and engine oil lubricants, providing significant savings on maintenance costs. Exhaust emissions have also been proven
to be reduced by more than 80%. Other emissions reduced are hydrocarbons (HC), nitrogen oxides (NOx), carbon monoxide (CO), particulate matter (PM) and
other harmful by-products of combustion.
CONTINUOUS USE
Many people make the mistake of expecting optimal fuel economy results on the first tank of fuel mixed with Atoms PowerZ.
Although the majority of the people do get results on the very first tank, there are people who don’t. Please remember that
your engine has been running on incomplete combustion for a long time and as such carbon deposits would have already built up.
The first application clears away this carbon deposit, thus preparing the way for an efficient combustion thereafter.
Long-term benefits of Atoms PowerZ start appearing after several weeks of continuous use. As the reformulated fuel continues to run through the engine, the natural
esters which have very small molecular structures starts penetrating the imperfections on the metal surfaces of the engine, forming a lubricating
layer of film between all moving surfaces. As a result, the engine begins to run noticeably smoother with less power-robbing friction and heat.
Engine performance & engine efficiency continuous to improve measurably, over a period of months and fuel savings will be very evident from then on.
As long as the use of Atoms PowerZ mixed in fuel continues, superior engine performance will result. If you have a new engine, it will run better than new.
If you have an old engine, its performance will return closer to the manufacturer’s specifications.
VERDICT
Anyone can make a difference in air quality and protection of the environment immediately by just adding Atoms PowerZ into their fuel tank.
Unlike other environment solutions, Atoms PowerZ does not require expensive equipment, complicated installations or modifications to immediately
benefit from it.
Atoms PowerZ comes in a packing of 2 bottles in 1 box.
Each bottle contains 240ml of Atoms PowerZ.
Improve Power + Performance
Improve Mileage
Increase Horsepower + Torque
Increase Engine Life
Reduce Fuel Consumption
Reduce Toxic Exhaust Emissions
Reduce Noise, Vibration & Temperature
Reduce Maintenance Cost
Prices: 1 bottle $27
1 twinpack(2 bottle) at ONLY $50
Free Delivery!!!
Contact: 91547435
Email: [email protected]
