huuh.. <_< serious la bro.. aparaaOriginally posted by crower75@Mar 2 2005, 12:20
It would mean that your car will TEBABOOO anytime heheheh
Kidding...
Kidding...
Originally posted by antuquboq+Mar 2 2005, 12:45 -->
QUOTE (antuquboq @ Mar 2 2005, 12:45 ) --QuoteBegin-crower75
@Mar 2 2005, 12:20
Kidding...
huuh.. b][/quote] Antu ..jangan marah daaa.... My car now got error code also which is 007 ... Anybody know what its mean? .... :P |
Originally posted by BudakBiru+Mar 2 2005, 16:51 -->
QUOTE (BudakBiru @ Mar 2 2005, 16:51 ) Originally posted by antuquboq@Mar 2 2005, 12:45
@Mar 2 2005, 12:20
Kidding...
huuh.. b]
Antu ..jangan marah daaa.... My car now got error code also which is 007 ... Anybody know what its mean? .... :P [/quote] where got 007 code laa .. 7 got laa .. if 7 .. TP sensor loorr .. could be the sensor wires dah tercabut or need servicing |
meaning the problem is still there laa .. better check ..Originally posted by killgerms@Mar 2 2005, 18:04
me also kena code "007". Check engine light nyala. After switch off engine, then start back, check engine light gone, but the error still blinking. After cabut the battery the problem gone...why aar? one more thing, how the best way to reset the ecu..can reset ke the ecu? me dont know la.. :unsure:
Originally posted by antuquboq@Mar 3 2005, 09:41
poji.. yup last time got vss sensor problem.. now oil pressure swith lak.. already clean the socket.. very dirty.. but still got that problem.. start engine after 2-3 minute the CEL will appear.. i think my engine oil running low la.. need to topup
Antu .. your car now sudah advance laaa... tak mau lawan lagi .... ;)Originally posted by antuquboq@Mar 3 2005, 09:41
Originally posted by antuquboq@Mar 4 2005, 09:22
b]
Originally posted by coldfish@Mar 28 2005, 03:41
antuquboq
CEL22 is common for B-series engines with VAFC or VAFC II if your VTEC crossover point is different (usually higher than) from that of your ECU's. Usually happens when you raise your RPM slowly pass VTEC or just play around the VTEC crossover zone slowly.
For example:
Your ECU VTEC crossover = 4500RPM
Your VAFC VTEC crossover = 5000RPM
When your engine passes between 4500, your ECU is thinking it's time VTEC is engaged. But if the ECU does not sense the required oil pressure to engage VTEC in the solenoid (let's say because it's at 4900RPM, the VAFC did not activate VTEC yet), it throws a CEL22. Between 4500RPM and 5000RPM your ECU is wondering what the heck is happening because it's giving orders to the VTEC solenoid to work but yet it's not doing so. So it throws a red light in your face to tell you "uh oh... your engine is bitching on you". But in fact, your VAFC is the one delaying the orders. Your VAFC cannot tell the ECU that it has changed the VTEC crossover point to a different RPM. It is a piggyback computer, not closed-loop self compensating. As long as you use a VAFC/VAFC II with a different VTEC crossover point from your ECU, chances are you may see the CEL22 if you raise your RPM slowly. CEL22 does not put your engine into limp mode.
However, the CEL22 will not show if you step on it WOT and the RPM climbs quick enough.
Some people have claimed that cleaning the small gauze filter between the VTEC solenoid and the engine can eliminate the problem. But there's no guarantee you won't get a CEL22.
If your engine is really running low on oil, your oil pressure warning lamp will appear before the CEL.
Good luck.
[snapback]845656[/snapback]
Originally posted by antuquboq+Mar 28 2005, 16:41 -->
QUOTE(antuquboq @ Mar 28 2005, 16:41 )
--QuoteBegin-coldfish@Mar 28 2005, 03:41
antuquboq
For example:
Good luck.
Originally posted by md8366+Mar 29 2005, 11:50 -->
QUOTE(md8366 @ Mar 29 2005, 11:50 )
antuquboq
For example:
Good luck.
thanks coldfish.. so that it's normal thing will happen to all peps when they using vafc 1 or 2 rite? i got that prob after i install vafc.. that why la when i drive slowly my cel alwayz appear
[snapback]847474[/snapback]
i'll give my idea n advise base on what i know so!
i will choose to reply or not...
