how to pump??... use ur hand and pull the throttle cable??... got arr... coz i lazy wanna go inside the car and press the accelerator.... so i pump from the throttle cable lorr... at first jerks a little after spraying... the pump few times, felt smooth adi.....fstrader said:cannot cannot sifooo, u must use ur hand (palm) to pump it also![]()
weber sifoo, i using normal Aisan carb found in normal stock standard iswara wor... weber carb layout same with Aisan carb???.....:shocked:
btw, *off topic*... i jz installed NGK G-power platinum tip sparkplugs... but the feeling like worse than my old standard NGK plugs wor.... why arr??... coz the sharp tip causes a small spark??....
and, my friend said his mech last time did something to his car distributor to send higher current to the plugs... then he re-gap the plugs to make it wider...
so my theory was, higher ampere will be easier to spark... if wider gap means bigger spark.... thus, better complete combustion.... correct arr sifoo sifooo??....
i even cant saw this car in Auto saloon 2009...
