Check it out:
http://www.mudah.my/A+Spec+Hi+Rev+B20B+Type+R-13693448.htm
What you think for the price and specs that come with that price?
RM28,000, the 'Feel's Performance formulated B20 block' itself might count for 1/3 of the total cost.
Looks like a project done proper, with breather box retained. I like it when they opt for stock bore. With postal fees thrown in individually (not grouped items discounted postage fees), the figures should be somewhere along the following:
*ARP Head Stud - RM450++
*Crank 3 points girdle - RM1,500++
*ACL Race Bearing - RM300++
*ARP Block Stud - RM250++
*B20 H-Beam Forged Conrod with 84mm forged piston - RM2,500++
*Breather & adapter - RM400++ (breather looks OEM, adapter looks from machine shop)
RM5,400
*Skunk2 Pro 3 racing camshaft
*Skunk2 valve spring & retainer
*Skunk2 adjustable cam pulley
*Block fitting sleeves
*Block guard
*Racing water pump
*Racing oil pump
*Oil squirters
*Stroke =>89mm, made in Australia
89mm is stock B20B stroke. Not sure which part is made in Australia.
A quick look at Honda's high-revving engines, the stroke is highest in B18C Type R:
1. B18C Type R JDM: Bore x Stroke = 81mm x 87.2mm, Redline = 8,700rpm
2. K20A Type R: Bore x Stroke = 86mm x 86mm, Redline = 8,400rpm
3. F20C: Bore x Stroke = 87mm x 84mm, Redline = 9,000rpm
4. B16B: Bore x Stroke = 81mm x 77.4mm, Redline = 8,600rpm
Not sure about high-revving with a stroke as long as 89mm. Uncle Wiki says:
Formula 1 engines use short-stroke designs because it allows the engine to rev higher. Because of this, they are capable of generating greater horsepower compared to a long-stroke engine with the same displacement.
Sportsbikes and their racing version use short-stroke engines.
http://www.ford-trucks.com/articles/november2002/compress_image002.gif
