Yeah, I mean stock drop in is better in terms of filtration. You never hear Ferarri or Lambo owners sing praises to K&N filter don't you? Did you red the blog post at the bottom? I did not mean open pod also. Looks like you are the one who got me wrong.Again.
---------- Post added at 03:30 AM ---------- Previous post was at 03:24 AM ----------
If SVDO can reflash, can intro to me? I want to change my stock mapping.
The workshop that can do that con-lan-firm rich already lor. AFAIK, SVDO ecu's cant be reflashed, only works if you have a standalone management.
And, for filter papers that get clogged up,
does not impair air flow. It has been tried and tested. Actually it is better if it is covered with dirt, it helps with the filtration,
without impairing the air flow. K&N filters are based on the concept also, am I correct? The more the filter is dirtier, the better the filtration. Oxygen molecules are in an atomic scale, do you think a dirty filter will actually stop the passing through of the oxygen molecules?
