I think the muffler pipping inlet too big. Perhaps shift to others exhaust workshop for listen to 2nd opinion.
twinloops are supposed to switch from sflow to straight flow at a predetermined pressure which corresponds to a certain RPM (normally open to straight when vtec engages). did u hear any difference in exhaust note thruout yr rpm range?
but first of all...ori twinloop? no matter how lousy the muffler, it should not affect yr top speed by that much...
I have heard nothing but bad about replica twin loop mufflers.
Either go back to stock or find some JDM mufflers from half-cut.
Good luck.
He said it's not ori. It's a replica. Meaning it's probably just a loop around the muffler to the exit. Ie- it's a straight flow.
CRV auto with almost no back pressure... bad idea.
So do you recommend to install back my Catcon or get a new bullet in order to get back pressure bro ?
Haha yup bro...same goe to me...It sound so horrible it's like the exhaust piping vibrating when we accelerate...But is there any power loss when decat while having aftermarket muffler bro ?
If it is the cause I will simply get the bullet install on the exhaust system...?
MY FC IS BAD FOR THIS WHOLE WEEK BECAUSE I'VE NEED TO HIT THE PEDAL TO A BIT MORE THE USUAL BECAUSE IT'S HEAVY WITH THIS MUFFLER...![]()
It could be due to your installation or the muffler itself was not in working condition. I'm using a replica twin loop muffler on my crv rd1 as well. No such issue of having lower max speed. As the matter in fact, I felt it to be more responsive and powerful after installation. After installation max speed can easily go to 150km/h. After bot, easily up to speed cut and more but yet to remove the speed cut. My current exhaust setup is 2.5" piping all the way with mid bullet ending with twin loop muffler. I'll suggest u bring the muffler to other workshop and test it out. My best bet, the muffler itself could be leaking or there is some leaks in your exhaust system.
Good to see RD1 owner with this Mugen...How much is the price to do the piping?
and where is the shop you did your piping...
please I'm suffering driving my powerloss RD1![]()
Where are u at? I bought the twin loop muffler for 4xx new, made out of stainless steel. Did the piping for 3xx including the mid bullet. FYI shortly after I installed the said muffler, noticed a leak near the original mid bullet of the original piping thus I replaced the whole piping. Guess rust already set in for some time and the additional back pressure from the twin loop muffler sprung the affected area a leak. Do check it out.
Oh I see...My piping is all in clear orange...might say it rust but unoticeable...and I did also install new bullet replace for my old rasonator box and catcon...but remain the original pipes...
If I replace only the exhaust piping how much would it be the price...I'm in Ampang area...Where did you do your piping exhaust bro ?
Really need to do the same setup as your since you have a good feedback...
