AE111 BT and AE101 SEG BT....engine is the same ....SEG BT only can found on AE101 SEG WAGON....SEG WAGON dashboard is totally same with the local SEG , only different WAGON using digital aircorn panel and white white meter with 9k RPM, which is most wanted meter for SEG gang (i guess). if u can found WAGON halfcut, just plug and play on the engine and also all the wiring including the dashboard wiring, no single wire modify. while AE111 need to do some wire modify if you use back you local SEG dashboard, but dont know AE111 dashboard can fit to local SEG AE101 or not.
http://i88.photobucket.com/albums/k200/benjaminn78/dashboard.jpg
