4g93T gsr engine rebuild, need advice
Thank god i made it this far, :party:
I've already mock fit the crankshaft and checked the main bearing clearance. So far the clearance is just nice.. i was gonna assemble the lower end yesterday, but canceled my plan coz afraid if i let the short block lay around for a week or two before mounting it back in.. i'm afraid if the oil around the journal and bearing would drip down and than there wouldn't be enough oil supply around the journal during the initial start up causing damage to the bearings/journal.
Any helpful comments? :confused:
Hehe 1 more...make sure no extra bolts left in ur hand after u done with everything.
Hahaha thats rite...always use with rubber glove when installation.
Yeah.. bought a box full of that surgeon type latex gloves. Dirty a bit just throw away. As a result, quality control was a lot better. cleaner too.
hehe.. so far after completing short block no extra bolts. But shortage of bolts for w.pump and some other external accessories. Must have misplace them :banghead:
anybody can help me with my setbacks?
1. the engine started ok. But the electricals (pwr. window, radio...) is not functioning. Plus the "check battery" sign wont turn off.
2. There's a kind of air bleeding out sound coming from the int. manifold/t.body area.. has anybody have a diagnosis or any idea to solve this.
other than that oil pressure register ok... the aladin lamp light has gone off unlike before the rebuild.
Pls advice..
i have to see the engine myself to help u solve your problem but do u mean check engine light or the battery indicator light?.
1: if the battery light won't turn off it has to do something with your alternator. trying checking your harness if it's wired up correctly and your alternator belt is in place.
2: could be a busted gasket within those area or u missed a few bolt/nut in those area.
anyway just give me a call bro. will try and help u out.
Lazarus.. is the "man". :adore: :adore:
Hehe always bothering the sifu. Will call u later la bro.
Yeahhhhhhhhh Lazarus are man of 4G93 good man and helperss:biggrin:
Anybody have experience with oil leakage around the valve cover @ head area.
Oil is dripping a lil bit on the C.A.S side.. maybe coz i forgot to change its o-rings. Another leakage is around the cam pulley/valve cover on that side of area. I've put some RTV silicone gasket on the valve cover area, but maybe it isn't perfectly spread or maybe its leaking from the cam pulley's oil seal area. I'll post a pic when i can.
Pls advice...
Pls advice...
this problem is normal for gsr turbo,is the engine oil pressure no place out,bore the oil breathe hole bigger and put bigger pipe will be solve this problem,but must fix the oil seal also~
I'll do that.. maybe just bore & weld a small diameter pipe temporarily. Later do proper an fitting... that is once i can afford a proper oil catch tank. :confused: :confused:
Must take off the timing belt again once more to change campulley oil seal.. arrghh:banghead: :banghead: :banghead:
Appreciate the advice bro
I am hearing a tikka..tikka..tikka sound when the engine is in gear and driven. So far only when at WOT. And it is in sync with the RPM. A little bit sound like lifter, but during idle or not in gear there's no sound.
I'm a bit dishearten bcoz of d sound. Hope anybody can giv any suggestions fast... The engine already clocked 900km. Gonna re-measure the rod bearing clearance soon. Hope it's nothing serious or mortal.
Hopefully will sort all the little errors/problems ASAP. Then only can sleep well.. :argh::argh::bawling::bawling:
Your car sounds a bit like mine did. I had the same tik tik tik sound at low rpm and driving further will caused more problems. How loud is yours? I had bearing/conrod problems in the end and turns out it was due to low oil pressure from my oil pump. My turbo broke down as well as a result, conrod got burnt and bearings were scratched with silver shavings in the engine oil. I`m no expert and your case might not be the same as mine but driving slowly or not driving at all until you get it checked out would be good.
Pls advice...
Always use the Original OEM seal.Good for u.price little bit expensive.
Just completed bearing clearance check up after 1k run-in period. Clearance is still in tolerance, crank pin looks fine, bearing surface still isn't perfectly scrub in..
Lifter noise.. minimal.
Have to monitor the motor's condition to make sure everything runs and stay fine.
mebe the tick tick sound is from preignition(knocking) kot..coz during w.o.t only..have u tune ur car before running in?assumed this cause ur bearing all checked fine..
New Posts
