dont hot.. since you say your rpm is not working i guess you should double check again the wiring. if you are using distributor, maybe you can wire a new wire for your gadget and do not need to splice thru the ecu wirings...if you are using direct firing, perhaps you could try to get signal from your diagnosis socket box there and check from there... because there u will definitely wont go wrong with the ecu wiring as the label is at your diagnosis cover.
hi guys,
im interested in BOT my car. im driving a satria 1.6 SOHC. so far im satisfied with my car, just need a bit power kicks in :P
i was browsing this forum, and saw joeker's car, a G92P BOT. can u advice me on BOT. what to get, budget, things to look out... do i need to change my engine's head? does changing from SOHC to DOHC head will effect my BOT project?
so far for a start, i was thinking of buying an e manage first..
that's a powerful 4g92p.2++whp wor....
Similar threads | |
