[DIY] Flush ATF and change filter
Well if you're interested in a gasket removal tool and a paint scraper, come we DIY and you can try both. Then only decide which one is the right method for you. I got my tools at non ACE-Hardware places. ACE tends to be more expensive (significantly more) although their variety is extensive. Places like MTIS and Knights Auto are way cheaper and also have shitloads of tools. I don't recommend a knife btw, I've done this method before and snapped the blade which was a bitch to remove.
Kevinho
94
Puchong
Nice, paint scrapers also known as putty knife, I read alot of people use this to separate the oil pan.
Jom DIY, when you free bro ?
What exactly do you want to do first? I'll need to plan a weekend if it's a big job
Kevinho
94
Puchong
Hmmm,
My ATF oil change is over due 2000 km.
My absorber mounting got kluk kluk sound Dy.
One of my absorber is leaking, needa change Dy.
, Damn alot of stuff needa change but I think we can just start with ATF filter change and flush first. The others I think I can handle since I also need to spend some time on writing my thesis as well. Don't wanna use so much of your time also.
Hmmm,
Do one shot lah bro,there is 2 of u.
It will be like a therapy session for Iszo.
Drain the atf then change the absorber and mounting.this way u dont waste time waiting for the atf to flow out.
But they don't have the adsorber spring compressor tool.....
Kevinho
94
Puchong
True also bro, can change the absorber mounting while draining the ATF, I think since the ATF is draining, can Pasang the ATF cooler also
Hi all. sorry to revive old thread. Can I use engine oil flush to flush atf? Im afraid it will harm a/t component inside.
The reason i want to flush & clean it coz it has sluggish and hard shifting. My a/t also did not have a sump and also don't have filter.
I assume it already sludge inside.
Or do you guys have any suggestion to clear ATF sludge?
what car?
the easiest way could be atf with a tiny bit of diesel fuel? maybe...
the hard way is change atf normally...
then let it warms up, cycle the shifter P-R-N-D-2-L multiple time in short period (proper stop and moving is a must)
and then quick power burst acceleration+deceleration...
and then drain the oil again before refilling back the atf normally...
btw.. if stock 1st gen myvi, can get away changing the strut mount with just "cargo rachet-strap" cheaply available in diy shop...
Can do this but the author say it's dangerous
Oh heck no.. the amount of force in a spring is enough to destroy a lot of things. Besides, if you change the absorber mounting and absorber you need an alignment. Might as well get the suspension swapped out at a reputable tyre shop or one that you know in person.
ATF and all - easy. Just need to set a date/time. 2000km isn't a lot to exceed ATF unless you're telling me you've been running it 100k km la.
He wants to fit atf cooler also....:driver:
Dear All,
I have one question regarding Toyota Harrier 2.4 G specifications.
I went to used car showroom & I'm very interested to buy Harrier 2.4 G but i'm just curious about the spec. what i mean is for example,
1. 2004 Harrier 2.4G: RM 124k (have sunroof & he said not recon but imported straight from Japan from the start)
2. 2004 Harrier 2.4G: RM 109k (recon & 1 owner & no sunroof)
then I search on internet, (from what I understand) Harrier have spec 2.4G & 2.4GL (L Spec)...
