Thats honestly not bad. Clean only then extra 6bhp. Hehe.No la haha, a bit of balancing, polish a bit here and there to make the engine efficient.Mind you its only increased 6bhp from stock not much. Anyway everthing inside is stock 4g15 part..
Om paper is 200, but it is so old now, probably down to 170 maybe.....hhahahhaha![]()
Definitely not jumping it though. First stop is little boost only, like about 0.4-0.6 bar?
That should give about 120 - 140 bhp? But before that, I'll get a manual so that my car can actually do 90 bhp.
That numbers feel so bad. Somewhat.
FLP Garage Works: 4G15 SOHC I4
The little Mitusbishi that could?![]()
Ah, so you're using the 3 speeder now? Should consult the legendary FSTR a.k.a unker Fred. He used to win races with his 4G15 auto... Yours is MMC or VDO?
I thought you got mod it...
I think my engine is even worst... I tried driving Myvi 1.3 manual before. That engine is better than my 4G15. Response, acceleration and torque (can pull the car well even at very low rpm). THis means my 4G15 is even weaker than K3-VE... But then again, K3-VE had more valves than mine and also DOHC with VVT-i... What 4G15 had more is displacement...![]()
But if not how to go 250bhp on 1.5 liters?![]()
btw,what is the black canister thing on the firewall inside the engine bay?
Is that the fuel filter?
Slowly slowly sure got.You want? Budget got or not? If got anything is possible. The Merrill Performance 4G15 had way more power than that.
Erm.. mine not stock internals.
There's two, which one? The wiper motor and the fuel filter. Oh also got the charcoal canister.
This makes me sad.....it means my mom's 4g15 probably producing 60 horses only.
My waja already below 100hp maybe.
So slow.....
Probably whats left are not even pure breed horses,just some pony or worst wannabe donkey.kuda padi still ok lah.
Yep 3 speeder. Must ask mr fstr already. Its a VDO. Kind of wished it wasnt though.
Because I feel that it is not as powerful as before, or maybe butt no more feel......hhahahhahah
The canister, check what is attached to it. Fuel line then is fuel filter. Vacuum hose then is charcoal canister...
---------- Post added at 06:51 PM ---------- 6 hour anti-bump limit - Previous post was at 06:50 PM ----------
Already from 100 plus auto to 200 manual, why mod some more.....![]()
People always say once you go for forced induction, you will always want to go for higher boost.
BTW, do you know what can be done to restore back 4G15's power back to the original output? Because from the way it is now, I think it is under performing until it is weaker than K3-VE.
Standard boost from factory already 0.6, so don't suka suka go and meddle the boost without doing it right.....
Looks like the engine is worn down. Complete overhaul will bring it's power back......![]()
Hmm, I thought 4G63T had boost level of over 1.0 bar... Or maybe those are the Evo 4G63T....
Normally how much for overhaul? The engine has clocked around 197 000km... I know that is a lot already....
Mine is MMC manual... Inherited from family. Glad that my father bought this car at the right time.
Depends what are being changed, probably bro. Izso can give you a better insight as he had a Wira before.....![]()
I wish mine was MMC too.![]()
Mine did 247k. I think I need an overhaul quite badly. Also, the remapping and piggyback support. GAAAAHI think his engine had been rebuilt many times. Yeah, I should ask him about it.
Well, according to Izso, being MMC doesn't make much difference? I only know that MMC are able to remap and supports more kinds of engine management. But then again, it still feels cool to be Mitsubishi, haha.![]()
Mau turbocharge mah. Need to remap somewhat.Woah, that's quite a lot. Your car should be newer than mine since using VDO. What year? Mine is already 15 years old and I thought 197k is a lot.
You're interested in doing remapping and piggyback?
Ikr. I have a feeling that the previous owner is some douchebag who doesnt care about performance. At least I got 15 x 6.5jj though. :biggin:
4G15 BOT? That is quite a big project. Forged pistons and stuffs. All the best for it.
Previous owner? So you just got the car recently? 15 inch is good enough for Wira.
)??? Been interested in this MR2s since I was a kid... hehehe...
